Author Topic: Differential Receiver  (Read 319 times)
Offline pixelpuppy
  • Kudos: 32
Re: Differential Receiver
« Reply #15 on: October 10, 2018, 09:33:51 AM »
Yes, I have 0 pixels.  I'll correct that tonight when I get home.
You also need to move the cable from DMX#2 jack to DMX#1 jack if you want to use more than one port on the receiver.  If you use DMX#2 or DMX#3 jack than only Port1 on the receiver can be used.   From the User Manual:
Quote from: F16V3 User Manual
The DMX1 jack (nearest to the top of the board) has all four serial circuits available.  The DMX2 jack has only the Serial 2 data. The DMX3 jack has only the Serial 3 data.
The DMX1 connector can drive all 4 ports on a differential receiver without the need for a differential expansion board.  A single port on the differential receiver can be driven if connected to either DMX 2 or DMX 3 ports.
Offline Rmaddox
  • Kudos: -1
« Reply #16 on: October 13, 2018, 12:55:28 PM »
I added 70 pixels to channel 1 on the string port page and saved, but I still don't have any lights.  I have the pixels attached to port 1 on the receiver.  I'm wondering why the first pixel always comes on?   As soon as I put power on the receiver, the first pixel comes on, even without xLights being on.  It comes on every time and the color is random.  The only way I can turn it off is to remove the power from the receiver and as soon as I plug it in, the first pixel comes back on.  I've plugged the pixels into the regular ports on the Falcon F16v3 and they work correctly.
  • Kudos: 51
« Reply #17 on: October 13, 2018, 06:45:27 PM »
That is usually a sure sign that your wiring to the pixels is not correct.  But I can't remember what is crossed with what.
Online JonB256
  • Kudos: 102
« Reply #18 on: October 13, 2018, 07:11:48 PM »
Does that string of 70 pixels work normally other than that First Pixel problem?
If it works normally, then I'd guess that you have a pixel overlap problem somewhere (a string count one pixel too long)
Offline Rmaddox
  • Kudos: -1
« Reply #19 on: October 14, 2018, 06:48:22 PM »
Thanks all for the help!  I got everything working finally.  I changed the Falcon port from 2 to 1, changed in xLights and interface to match and it works. Not sure why it didn't work on port 2 of the Falcon, I didn't change anything else.
