Welcome => Learning Center => Topic started by: Ken on February 07, 2017, 07:36:51 PM
Title: Where to start? Controller Configuration or XLights Network Configuration?
Post by: Ken on February 07, 2017, 07:36:51 PM
This will be my first year using pixels and I'm trying figure out where to start.  I think I've got a descent understanding of the hardware involved and right now I'm planning on using XLights and a F16v3 to control a 24 strand tree and 4 matrix's that are basically just going to be net lights for some bushes on either side of the tree.
I've watched several videos of people configuring the F16's and the XLights networks but I still haven't figured out which one I should do first.  Do I need to use a spreadsheet to map out where each element / string / prop will connect to the F16 first?  Or do I design the props and the layout in XLights first?  Or does it not really matter which one I start with?
Right now I'm thinking that I need to start with the F16 configuration and then map that to XLights but I don't want to start down that path only to realize later that I should have started somewhere else.  Any guidance you guys are willing to share would be greatly appreciated.
Title: Re: Where to start? Controller Configuration or XLights Network Configuration?
Post by: rstehle on February 07, 2017, 10:52:31 PM
You can do everything in xlights without worrying about any controllers.  Set up your layout, learn xlights, do your sequencing and even create a show schedule.  Once you have your controller(s), you can decide on channel assignments.  Have fun!
Post by: jnealand on February 08, 2017, 09:50:37 AM
Just create a network with how many universe you want in xlights and get started with sequencing.  Once you get controllers and figure out your connection, just go back, update the network and resave the sequence files.
Post by: keithsw1111 on February 08, 2017, 11:25:32 AM
As long as you follow some simple rules you can configure everything in XLights and then upload your configuration to both fpp and your f16v3. The main rule is when you have a prop that requires multiple outputs on your f16 do them in numerical order. If you can avoid virtual strings and colour reordering on the f16 then you should never need to setup anything of your f16 other than an IP address. I posted some videos on my YouTube channel just before Christmas demonstrating this.
Post by: esmiller67 on March 05, 2017, 10:53:25 PM
Keith.. is this the video you are referring to?
https://www.youtube.com/watch?v=ri0ZOIhpZ9U
Post by: Dabil on March 06, 2017, 06:44:27 AM
For sure start with xlights. And you should do that as soon as possible. I am a first year guy to, and I thought I knew what I wanted with some degree of confidence coming in. But once I built the show I thought I wanted in xlights, I found I couldn't do all the effects I wanted to be able to do because of issues with the design.
An example is that I love the whole house effects where things spin and bounce around the whole display. But my initial design had the pixels too clustered together so the whole house effects were being lost.
So I began watching videos and getting knew ideas and evolving my show design. During this process I realized that I really liked the megatree as the center of the show. It sets off the whole house effects and is the single most interesting prop in any show due to its flexibility. I found that all the sequences I really liked featured the megatree, which originally I wasn't going to have one in my show.
Through this evolution I figured out exactly what I wanted in my show. And I can tell you that my show now uses less pixels than my original design. And I can do both more effects and more interesting effects
Once you get your house design in xlights, and a few songs sequenced, next step is build the props. Every prop I built so far in real life I have had to change the model in xlights for it.
An example is with my matrices. I watched a video on building matrices from Matt Johnson where he built 30x34 matrices using 1" 200 psi pvc. So my original design in xlights had two 30x34 matrices. Then I found pixelnet which comes in 4x8 sheets and made building matrices way easier. Well I didn't want to pay for more than one sheet of pixelnet since it's $70 per sheet, and I still wanted two matrices. So I cut one sheet of pixelnet in half giving me 2 24x24 matrices. So that required a change in xlights.
When you create a matrix in your preview during the design phase,  xlights defaults to horizontal matrices. I found while wiring my matrices I didn't like having the wires coming in from the side. It made more sense to come in from the bottom since my controller was staked into the ground right below the matrices. So I changed my matrix models in xlights from horizontal to vertical.
And these examples are just a few of hundreds of little changes and tweaks that my show has gone through during it's evolution . So as you can see it doesn't make any sense to program your falcon controllers until you get things programmed in xlights and your props all built. Unless you like having to constantly go back and adjust that program with whenever a change occurs.
Also designing sequences you will find will evolve your show design as well. I started sequencing True Colors from the trolls movie, all of a sudden I realized I just had to have some boscoyo studios snow flakes to visually represent the sounds of the trolls getting their colors back. The previous 14 sequences I did I could care less about the snow flakes, but this one song made them a necessity for me. So there you have it, welcome to the addiction lol.
Post by: alindo01 on March 15, 2018, 02:15:47 PM
Boy you are right, I'm going through those pains now.
