Falcon Christmas => F16V2 Differential Expansion and Receivers => Topic started by: TNF250 on January 12, 2018, 09:16:05 AM
Title: RGB Staying On
Post by: TNF250 on January 12, 2018, 09:16:05 AM
When the show stops. I have one receiver that always leaves 1 RGB lite on 2 props of the 4 used ports until power is removed for 30 seconds. Once power is back on the lights are off and stay off until the show runs again. Any suggestion on how to fix this?
Title: Re: RGB Staying On
Post by: JonB256 on January 12, 2018, 12:12:38 PM
First pixel, showing green ?  I have one of those.
Post by: algerdes on January 12, 2018, 12:29:33 PM
I'm not sure what is causing it, but you can check a few things:
What voltage is present at that pixel?  Is it above 12vdc?  (Assuming you are using 12vdc pixels.)
Are all your connectors clean, dry, and properly seated?
If your power supply is putting out above 12vdc, you may want to drop it down to around 11.9 and see if it still does it.
Post by: TNF250 on January 14, 2018, 09:30:23 AM
Most of the time blue but it does change.
Post by: TNF250 on January 15, 2018, 02:20:28 PM
Are all your connectors clean, dry, and properly seated? I'll have to pull it back out at check the voltage. Yes everything was clean and dry.
Power supply was set at 11.9 at the beginning of the season but will check again.
