Author Topic: Ethernet Ports not working  (Read 233 times)
Offline Rod R
« on: November 28, 2018, 07:00:11 PM »
Hi All,
Anyone have an issue with both ethernet ports not working I check the cables with a checker and their fine even replaced them just to double check also switch ports on the switch same thing the board seems to be working in test mode.  I did fine a blown fuse this afternoon we had some rain.  No water in the enclosure and no water seeped into the cables I use the Amphonel sealed type. Any advice where to start.
Found the issue removed the board and checked the Ethernet Jacks looks like there was a couple cold solder joints on some of the pins went ahead and re-soldered them and everything looks OK now.
« Last Edit: November 28, 2018, 10:42:20 PM by Rod R »
