Author Topic: Want/Suggestion List  (Read 3720 times)
Offline MyKroFt
  • Kudos: 57
« on: July 16, 2013, 05:05:59 PM »
Please post your wants/suggestions on additions/changes to the FPP web interface.
I will consolidate them in the reserved posts so we can keep track of them, and what their status becomes etc.
Myk
Offline MyKroFt
  • Kudos: 57
Re: Want/Suggestion List
« Reply #1 on: July 16, 2013, 05:06:27 PM »
*** User ***
*** Want/Suggestion ***
*** Status ***
smeighan|Graphic Status Bar On Song Position|Unassigned
smeighan|Autodetect Slaves|Stage 2
smeighan|Date/Time of files|Already Listed
MyKroFt|First/Last Play Once Entries In Playlist|Unassigned
MyKroFt|Weekday Only/Weekend Only Day Selection|Unassigned
MyKroFt|Add Video Management|Unassigned
MyKroFt|Add RDS Management|MyKroFt
« Last Edit: July 16, 2013, 06:13:27 PM by MyKroFt »
Offline MyKroFt
  • Kudos: 57
« Reply #2 on: July 16, 2013, 05:06:40 PM »
Reserved
Offline MyKroFt
  • Kudos: 57
« Reply #3 on: July 16, 2013, 05:07:22 PM »
Reserved
Offline smeighan
  • Kudos: 11
    • Nutcracker123
« Reply #4 on: July 16, 2013, 05:28:22 PM »
It would be nice to see a bar showing where a song is, similar to itunes.
I would like to see the date stamp of the last time i modified a file.
Autodetect the pi slaves and have a menu showing the,m
MASTER
    Slave 1
    Slave 2
Clicking the Slave tab opens their screen . Now i can upload mp3's and mp4's to that slave. I can assign videos to the video slots
Sean
Offline Materdaddy
  • Kudos: 10
    • Christmas On Quiet Hills
« Reply #5 on: July 16, 2013, 09:39:20 PM »
I was going to mention RDS (like in the UI preview thread), but I see that's already on the list, and already assigned.
Offline Materdaddy
  • Kudos: 10
« Reply #6 on: July 17, 2013, 12:11:09 AM »
Installer/Updater
This would be something for initial installation.  For people that don't want to download a large(ish) pre-installed raspbian image for the player, there should be some sort of easy installer to be used.
Similarly, there should be an easy way to update the installation people are using when new features are made, or bugs are fixed.  Instead of having to re-download the entire SD card image, they should be able to easily update their PI.
Once I become more familiar with things, I wouldn't mind working on this.
« Last Edit: July 17, 2013, 10:56:04 AM by MyKroFt »
  • Kudos: 76
« Reply #7 on: July 17, 2013, 01:39:00 AM »
Installer/Updater
Your help is much appreciated. I know you helped with Nutcracker 2 with update script and we need something similar.
Thanks.
Offline MyKroFt
  • Kudos: 57
« Reply #8 on: July 17, 2013, 10:56:23 AM »
We are gonna use the NOOBS (New Out Of Box Setup) that they have designed.  It has a fail safe that if you corrupt your sd card, all you have to do is hook up a keyboard and a monitor, and when you boot and when it tells you on the screen, hit the shift key and it will go into fail safe to let you reinstall the image in a matter of minutes without having to take the sd card out of the pi.
As far as updating etc, every time you boot it will check for a update (has to be on net) and also there will be a manual update in the GUI with some sort of notification it found a update.
Myk
Installer/Updater
Offline Materdaddy
  • Kudos: 10
« Reply #9 on: July 17, 2013, 12:17:08 PM »
Exactly the type of thing I was thinking of.  Is this on the TODO list and assigned?
Offline MyKroFt
  • Kudos: 57
« Reply #10 on: July 17, 2013, 12:20:26 PM »
Its already being worked on, I am working on the NOOBS stuff, and will prob use github to pull down the updates as David and I are using it already to keep track of stuff...
Myk
  • Kudos: 118
« Reply #11 on: July 17, 2013, 05:25:13 PM »
My PiWireless will be handy for updates.
Galaxy Note II
