Author Topic: What Output Type do I use for WS2811 Pixels attached to a PICAP on FPP 2.5.3?  (Read 307 times)
Offline mikeklingler
What Output Type do I use for WS2811 Pixels attached to a PICAP on FPP 2.5.3? I was watching a video that showed using RPIWS281X, but I don't have that option in version 2.5.3 of FPP. What do I use instead? I'm not a newbie to RGB lighting, however I am a newbie to Falcon Player and FPP PiCap. Any help you can give would be much appreciated! Thanks!
  • Kudos: 43
Look under Input/Output Setup -> Channel Outputs -> Pi Pixel Strings
Ahha! it moved from Input/Output Setup ->  Channel Outputs -> Other. Thanks for your quick response! :-)
  • Kudos: 214
Yes, it moved and got a major upgrade with the support for Virtual Strings and other new config options.
