Author Topic: FIRST TIME ADVICE FOR FALCON PICAP SET UP HERE IN THE UK  (Read 311 times)
Offline Discoeye
« on: January 11, 2019, 09:23:05 AM »
Hi to all on the forum. I am a uk resident setting out on my first adventure to controlling pixel lights via a pi 3b+ and a falcon picap
for christmas of 2019.
I am a complete novice of all devices but consider myself very competent if given the right guidance , i have read the best approach is to work backwards from the amount of pixels i will be using to determining the power required.
I value any help possible please from the forum to help me in my quest.
regards discoeye
Offline Bwinter
  • Kudos: 10
    • First Show 2016
Re: FIRST TIME ADVICE FOR FALCON PICAP SET UP HERE IN THE UK
« Reply #1 on: January 11, 2019, 10:32:30 AM »
So what specifically are you stuck on?  Installing FPP, wiring, configuring?
Offline Discoeye
« Reply #2 on: January 11, 2019, 11:52:23 AM »
Hi,
thanks for looking at my post. I am awaiting my falcon picap and im confident with the software side of things with my pi 3b+ its just the wiring side of things.
My project is to make 4 chasing arches/arcs over a distance of 8 meters so 2 meters per arch/arc and i have no problems making these i thought strip pixels and tubing but im unsure on 5v or 12v lights and the whole wiring process.
Thank you and kind regards Discoeye
Offline Bwinter
  • Kudos: 10
    • First Show 2016
« Reply #3 on: January 11, 2019, 11:56:19 AM »
I think you'll be in pretty good shape.
Have you selected what type of LEDs you're going with?  Bullets/nodes or strips?  Are the LEDs inside some tube (i.e., weatherproof), or are the LEDs going to be exposed?
Basically, you want WS2811/WS2812 (WS281x) type of LEDs.  They have a wire/connector for VOLTAGE (5v or 12v, your choice), GROUND and DATA-IN (connected to DATA-OUT of your PiCap).
Offline mac50
« Reply #4 on: January 11, 2019, 12:12:07 PM »
Here is a video on power calculation   https://www.youtube.com/watch?v=XxOdUJweQbA
Offline Discoeye
« Reply #5 on: January 11, 2019, 12:21:06 PM »
Hi,
thanks for the link.
Kind Regards Discoeye
Offline Discoeye
« Reply #6 on: January 11, 2019, 12:33:40 PM »
Thank you ever so much.  So Picap on top of rpi 3b+ power supply to cap which would power rpi ????? lights from cap
would that be correct.
I have the link with regards to calculating how much power which will determine what psu to get, any additional wiring i need to know of or would be wise to have .
Forgive me for all the questions but i don't want to go out in a puff of smoke.
Offline Bwinter
  • Kudos: 10
    • First Show 2016
« Reply #7 on: January 11, 2019, 12:39:33 PM »
Many people supply power through the PiCap--and this powers both the Pi as well as the LEDs that are attached (makes the overall wiring much simpler).
However, there has been some reports that the Pi 3B+ draws more power than the PiCap's on-board buck-converter can provide.  In this instance, you might need to power your Pi3B+ separately from the LEDs.
Offline Discoeye
« Reply #8 on: January 11, 2019, 12:50:17 PM »
Ok thanks for the heads up. Any recommendations for a good power supply i think i will be going with 12v pixel strip lights.
Thanks and kind regards Discoeye
