Author Topic: Volume Control Not Working - Soundblaster 3 / FPP v2.6  (Read 217 times)
Offline mikentn
« on: January 13, 2019, 06:20:55 PM »
Hello gang,
I decided I'd try setting up my FPP with a Soundblaster 3 USB audio card today (I previously had it set up with a HiFiBerry card). I decided to start with a fresh install of FPP, so I re-imaged my SD card with v2.5.3, and then upgraded to v2.6.  I grew the file system, then added back my usb drive, wireless dongle, and and the Soundblaster card.  I was able to choose the Soundblaster and speaker in the FPP settings menu, but for some reason the FPP volume control does not work at all.
Has anyone else with a Soundblaster 3 experienced this with v2.x???
« Last Edit: January 13, 2019, 07:36:47 PM by mikentn »
Offline lightingfool
Re: Volume Control Not Working - Soundblaster 3 / FPP v2.6
« Reply #1 on: January 13, 2019, 09:20:38 PM »
go to settings and change OMXPlayer (mp4 playback) Audio Output: to local
  • Kudos: 66
« Reply #2 on: January 14, 2019, 08:53:38 AM »
I was on v2.5.3 for the last month and the volume worked with my Soundblaster.
  • Kudos: 205
« Reply #3 on: January 14, 2019, 09:31:20 AM »
You may need to select a different mixer device, I haven't picked up a SB3 to test with yet so am not quite sure.
Offline mikentn
« Reply #4 on: January 14, 2019, 10:13:50 PM »
Out of town at the moment. I'll give this a try when I get back home.  Thanks!
Offline mikentn
« Reply #5 on: January 15, 2019, 08:27:33 PM »
OK, back home.
Tried setting the OMXPlayer Audio Output to local, still no volume control. Set it back to ALSA.
Changed the mixer setting from speaker to mic, then moved it back to speaker before I rebooted the Pi.  Now the volume control works. Don't know why, but not looking a gift horse in the mouth.
Thanks for everyone's responses.
