Author Topic: [COMPLETE][GROUP BUY] BeagleBone/PocketBeagle based controllers  (Read 8555 times)
Offline xmasnow
Re: [GROUP BUY] BeagleBone/PocketBeagle based controllers
« Reply #15 on: February 07, 2019, 11:06:11 AM »
I didn't see it mentioned, but I'm guessing these PocketScrollers will be V1.1 (or newer) with the additional "E" signal to support 1:32 scan panels?
They will be the 1.2 version which is pictured in the "Intro" thread.  They have the working E line.    The differences between v1.1 and v1.2 are:
1) Surface mount buffer chip
2) Additional ESD protection/prevention chip for the USB port to prevent static discharge issues plugging/unplugging USB devices while on
Pinout/capabilities are exactly the same.
Quote
Also, are you no longer offering your V2 Octroscrollers?
I have plenty of blank boards for them if anyone is interested.   My son is no longer interested in assembling them.  :(     I can easily throw the blank boards into any other order for $1.   I could also assemble a few kits if anyone is interested.   I'd need to double check, but I should have all the ports and buffers and such for at least 4 or 5 kits.
I also have blank boards for "F8-B v1.00" which is a fully through hole version of the F8-B minus the expansion port.   I don't have all the parts for full kits, but again, I can throw a blank board into any order for $1.   I have some of the parts, but definitely not all of them.
If someone wants something to learn how to solder on, they are great.  You could likely get a controller up and running fairly cheap and learn to solder in the process. The F8-B you could just order/populate the parts that are "required" for your use case to be even cheaper.   Example:  don't need the differential outputs?  don't populate the differential chips and RJ45 ports.
I'll take 4 of the F8-B blank boards and 2 of the octoscrollers... I'll include it in my paypal payment.  Thanks!!
Offline vjguerrero
« Reply #16 on: February 07, 2019, 12:52:59 PM »
Item               Qty   Cost   Total Cost
F8-B                   1   $48                $48
F32-B                   0      $92                $0
F8-PB                   2   $48                $96
F40D-PB           0   $41.               $0
PocketScroller   0   $16                $0
PocketBeagle   2   $30                $60
Shipping         $11
Total         $215
Offline aclarksr
« Reply #17 on: February 07, 2019, 12:54:32 PM »
Dan,
Add two each of your blank pcbs for F8-B & Octoscroller. Sending PayPal payment to add to current group buy.
Andrew
Offline mfroez
« Reply #18 on: February 07, 2019, 06:08:27 PM »
Dan
  2 F40d-PB  $82
  2 Pocketbeagles $60
     Shipping $8
 Total $150
Offline spcmky
« Reply #19 on: February 07, 2019, 06:43:43 PM »
ITEM   QTY    Cost      Total
F32-B   1     $92.00    92.00
Offline Cjaqua
« Reply #20 on: February 08, 2019, 04:55:30 AM »
Add two of the blank F8-B pcbs to my order. Thanks!
Offline peterazdig
« Reply #21 on: February 09, 2019, 10:48:21 PM »
ItemQtyCostTotal Cost
F8-B1$48$48
F8-PB1$48$48
PocketBeagle1$30$30
Octoscroller Boards3$1$3
Shipping$11
Total$140
Offline mtosh
« Reply #22 on: February 11, 2019, 08:11:42 AM »
F8-B 0 $48 $0
F32-B 1 $92 $92
F8-PB 1 $48 $48
F40D-PB 0 $41 $0
PocketBeagle 1 $30 $30
Shipping $14
Total
$184
Offline boxr1030
« Reply #23 on: February 11, 2019, 12:49:53 PM »
ItemQty CostTotal Cost
F8-B14848
Shipping8
Total56
Offline Gadjetman
« Reply #24 on: February 11, 2019, 03:00:16 PM »
Id like to be involved with this group buy
Let me know if I didn't calculate the shipping correctly, hoping you can send a package to Canada.
F8-B0
$48$0
F32-B0
$92$0
F8-PB2
$48$96
F40D-PB0$41$0
PocketScroller2$16$32
PocketBeagle4
$30$120
Shipping$20
Total$268
Online Sawdust
  • Location: Folsom, CA - - - - - - - - - - - Cell Block 7
  • Kudos: 8
« Reply #25 on: February 11, 2019, 11:28:57 PM »
F8-PB1$48$48
PocketScroller1$16$16
Octoscroller Board Only1$1$1
F8-B v1 Board Only2$1$2
Shipping$8
Total$75
Also see post #34
« Last Edit: February 18, 2019, 12:53:33 PM by Sawdust »
Offline todd1814
« Reply #26 on: February 12, 2019, 08:45:03 AM »
F8-PB               1   $48   $48
Shipping                        $8
Total                              $86
4 - F8-PB Blank Boards $4
« Last Edit: February 12, 2019, 08:55:05 AM by todd1814 »
  • Kudos: 92
    • KulpLights.com
« Reply #27 on: February 12, 2019, 08:54:54 AM »
Um... Hold on guys... I think I'm out of F8-B blank boards....    I only had a handful of them as they were a small order for prototyping.    I do have plenty (>25) of OctoV2 boards.
I need to dig around on my shelves and see what other useless stuff I can pawn off on all of you.  :)
Offline aadu
« Reply #28 on: February 13, 2019, 11:04:58 AM »
F8-B0$48$0
F32-B0$92$0
F8-PB1$48$48
F40D-PB1$41$41
PocketBeagle2$30$60
Shipping$11
Total$176
Offline k6ccc
  • Kudos: 6
    • Newburgh Lights
« Reply #29 on: February 14, 2019, 05:29:15 PM »
PocketBeagle1$30$30
Shipping$8
Total$54
Will pay via PayPal in the next couple minutes...
