Author Topic: [GROUP BUY] BeagleBone/PocketBeagle based controllers  (Read 4592 times)
Offline twooly
Re: [GROUP BUY] BeagleBone/PocketBeagle based controllers
« Reply #60 on: February 28, 2019, 06:56:33 PM »
ItemQtyCostTotal Cost
F8-B1$48$48
Blank OctoScroller2$2$2
Shipping$8
Total$58
Offline bassnbuck
« Reply #61 on: February 28, 2019, 07:02:53 PM »
2- pocket beagles  $30 ea
1- F40d-PB             $41
shipping                 $11
total                     $112
thank you Dan
Offline Broomy111
« Reply #62 on: February 28, 2019, 08:13:58 PM »
F8-B0$48$0
F32-B1$92$92
F8-PB0$48$0
F40D-PB0$41$0
PocketScroller0$16$0
PocketBeagle0$30$0
Shipping$14
Total$106
Offline firevideo
« Reply #63 on: March 01, 2019, 07:35:16 AM »
ItemQtyCostTotal CostF8-B0$48$0F32-B1$92$92F8-PB1$48$48F40D-PB0$41$0PocketScroller0$16$0PocketBeagle1$30$30Shipping$14Total$184
I'll take the following
Steve Siereveld
F32-B .  1 .     92
F8-PB .  1 .     48
Pocketbeagle .    1 .    30
Shipping                  14
total .  184
Offline rgbtac
« Reply #64 on: March 01, 2019, 05:42:11 PM »
Hi! I would like
1 F32-B     $92
1 F8-PB    $48
1 Pocket beagle pre mounted  $30
Shipping    $14
Total       $184
Thanks!
Offline TMerk
  • Kudos: 6
« Reply #65 on: March 01, 2019, 06:57:24 PM »
F8-B0$48$0
F32-B0$92$0
F8-PB0$48$0
F40D-PB1$41$41
PocketBeagle1$30$30
Shipping$8
Total$79
Offline paudyd
« Reply #66 on: March 02, 2019, 03:11:13 AM »
Can I still order two PocketScrollers and one PocketBeagle?
2 PocketScroller $32
1 Pocket Beagle $30
Shipping $8
Total $70
Offline critic2
« Reply #67 on: March 03, 2019, 07:57:26 AM »
F8-B2
$48$96
Shipping
$8
Total$104
Chuck P
Still Learning...💡
  • Kudos: 81
« Reply #68 on: March 06, 2019, 03:23:17 PM »
Update:  boards are now ordered.   Please make sure your entry in the first post is correct.   Make sure I have the correct types of boards you wanted and whether you have paid or not.
Also, I have ordered quite a few extras of each of the boards.  Thus, if you missed the cutoff date, don't worry.    Feel free to keep adding orders to this thread for now.  If it looks like I'll run out, I'll officially mark this thread as closed.
Thanks for all the orders.  I'm very excited to see the number of orders and number of boards ordered.  Definitely exceeded my initial expectations.
Offline Duane Johnson
    • Johnson Lights
« Reply #69 on: March 11, 2019, 09:58:30 PM »
F8-B0
$48$0
F32-B1
$92$92
F8-PB0
$48$0
F40D-PB1
$41$41
PocketScroller0
$16$0
PocketBeagle1
$30$30
Shipping$14
Total$177
Offline todd1814
« Reply #70 on: March 12, 2019, 01:06:10 PM »
Qty  Item                                  Cost
2     F8-B                                  $48
1     Additional Shipping             $  3
       TOTAL                               $99
I'd like to add the following to my order. I already paid $8 shipping so added another $3 to cover the rest.  If you need to change that amount just let me know.
« Last Edit: March 12, 2019, 01:16:14 PM by todd1814 »
Offline LazerBlue
« Reply #71 on: March 13, 2019, 06:04:09 PM »
I would like the following
Qty     Item               Cost
1        F40D-PB             $41
1        PocketBeagle      $30
          Shipping            $8
Total                            $79
Online aclarksr
« Reply #72 on: March 23, 2019, 06:24:45 PM »
I didn't see it mentioned, but I'm guessing these PocketScrollers will be V1.1 (or newer) with the additional "E" signal to support 1:32 scan panels?
They will be the 1.2 version which is pictured in the "Intro" thread.  They have the working E line.    The differences between v1.1 and v1.2 are:
1) Surface mount buffer chip
2) Additional ESD protection/prevention chip for the USB port to prevent static discharge issues plugging/unplugging USB devices while on
Pinout/capabilities are exactly the same.
Quote
Also, are you no longer offering your V2 Octroscrollers?
I have plenty of blank boards for them if anyone is interested.   My son is no longer interested in assembling them.  :(     I can easily throw the blank boards into any other order for $1.   I could also assemble a few kits if anyone is interested.   I'd need to double check, but I should have all the ports and buffers and such for at least 4 or 5 kits.
I also have blank boards for "F8-B v1.00" which is a fully through hole version of the F8-B minus the expansion port.   I don't have all the parts for full kits, but again, I can throw a blank board into any order for $1.   I have some of the parts, but definitely not all of them.
If someone wants something to learn how to solder on, they are great.  You could likely get a controller up and running fairly cheap and learn to solder in the process. The F8-B you could just order/populate the parts that are "required" for your use case to be even cheaper.   Example:  don't need the differential outputs?  don't populate the differential chips and RJ45 ports.
Dan,
Do you have BOMs for the F8-B and Octoscroller capes? If available already could you point me in the right direction?
  • Kudos: 81
« Reply #73 on: March 26, 2019, 07:21:43 AM »
I'm going to have to dig through some notes for the F8-B.  The Octo is relatively simple:
2 of 2x23 Male headers 2.54 (connect to BBB) - DigiKey 1528-2021-ND
1 of Buffer IC - SN74HCT541N - DigiKey 296-1655-5-ND
8 of 2x8 shrouded headers - DigiKey 732-2095-ND
3.5mm screw terminal - DigiKey ED2740-ND
I'll see what I can come up with for the F8-B.  The issue with the F8-B is that some of the parts (pixel connectors and fuses for example) are expensive on DigiKey/Mouser, but dirt cheap on eBay.
Offline Sawdust
  • Kudos: 8
« Reply #74 on: March 26, 2019, 11:31:55 AM »
Here are some opportunities to save money, if you have the time - Deliveries are based on West Coast Destination, near San Francisco.
Plug in terminals - Quick Delivery  Maybe 10 days
8 required
(use below for 10X or search other items for 40X or groups of 5 male or female.)
https://www.ebay.com/itm/2-3-4-5-Pin-PCB-Terminal-Block-Female-Male-Wire-Connector-Plug-in-3-5mm-20x/372412788987?hash=item56b58830fb:m:mjRk8rgpO4EyEmYH9I4bzGg
Fused - quick delivery - maybe 10 days.
1-2A & 8-5A
https://www.aliexpress.com/item/Fuses-car-Mini-Micro-Standard-Car-fuse-2A-3A-5A-7-5A-10A-15A-20A-25A/32854496963.html?spm=a2g0s.9042311.0.0.6a4d4c4dZXint6
Fuse Holders - 23 days.
https://www.aliexpress.com/item/20pcs-lot-Car-Fuse-Holder-PCB-Board-Medium-Mini-Blade-Auto-Automotive-Boat-32V-For-PCB/32978243928.html?spm=a2g0s.9042311.0.0.6a4d4c4dZXint6
IC from Arrow....no minimum, no freight, next day delivery.  (I don't know how they do it)
1-SN74HCT541N
3-SN75174N
1-1N5340B
1-0393800102 Molex power terminal
running 5V so didn't do IC1 or C6
Other stuff I had.
