Author Topic: Differential Receiver board 30amps spec  (Read 328 times)
Offline Eddy_9876
« on: February 08, 2019, 05:23:14 AM »
Hey guys,
  Im new to this hobby, and this Christmas will be my first show.  I have already brought a F48 and 2 Differential Receiver board.  I also have purchased two 5v 60amps power supplies.
But, it looks like I have already made my 1st newb mistake.  I overlook the Differential Receiver board 30amps spec.  It looks like I cannot power my receiver board with the 60amp power supply.
So, should I just buy two more amps (5DC 30amps) or is there a low cost way to step the current from 60A to 30A?
Has anyone else had this problem before?
  • Kudos: 77
Re: Differential Receiver board 30amps spec
« Reply #1 on: February 08, 2019, 05:37:35 AM »
Current is determined by the amount of pixels on the ports. Just reduce the pixels per port to be less than 30amps.
  • Kudos: 45
« Reply #2 on: February 08, 2019, 06:16:58 AM »
This is about understanding the difference between Voltage (force) and Amperage (flow)
Like David said, its ok to have a power supply with higher Current (amps) capacity than needed.     If you connect 30a of pixels to a 60a power supply, it will supply 30a to the pixels and leave 30a in reserve for other things.
But thats not the same with the Voltage.   If you connect a 12 volt power supply to 5v pixels it will fry them.
« Last Edit: February 08, 2019, 06:27:34 AM by pixelpuppy »
Offline Eddy_9876
« Reply #3 on: February 08, 2019, 09:12:50 PM »
David / Mark,
               Thanks for the fast reply.  Yes this makes perfect sense.  I had wondered if that could be the case, but needed to be sure.
Also, I just wanted to say. I really like the xLight software and the Falcon Controllers.  This is going to be a cool new hobby.  I cant wait till Halloween / Christmas.
 :D
