Author Topic: the script repository is empty?  (Read 141 times)
Offline psychobugjoe
« on: February 11, 2019, 05:14:08 AM »
Im running 2.5 just want to use the GPIO pins to trigger relays. when I go o the the script repository its empty. it was my understanding i need configure a ON OFF script.
Offline brichi
Re: the script repository is empty?
« Reply #1 on: February 11, 2019, 07:35:41 AM »
usually that means the Pi/BBB is not connected and out to the internet so it cant pull the scripts. Click on the person number up top and in the info page see if it says "unknown" for the update field
  • Kudos: 67
« Reply #2 on: February 11, 2019, 09:32:06 AM »
In the DNS field add 8.8.8.8 as one of your DNS addresses and that should fix the issue assuming you have a wired or wifi path to the internet.
Offline gc2016
« Reply #3 on: February 11, 2019, 08:48:44 PM »
1.1.1.1 works now too!
