Author Topic: p5 panels with pi zero w  (Read 482 times)
Offline ee351
« on: March 16, 2019, 07:29:11 AM »
Hello all!
First off I'd like to thank the developers of the Falcon Player, they did a fantastic job with this software.
Now onto my issue.  I am building a 2X2 P5 matrix and it works great on a pi 3 (driving with a pi hat using 2 outputs).  No flickering or ghosting, gpio slowdown set to 2.
On a pi zero w, I set gpio to pi zero and get some ghosting and flickering, and the sequence plays a little choppy.  I have tried other gpio settings which fix the ghosting and flickering, but then the sequence runs slowly.  I also shutdown the browser after setting changes but this doesn't correct the issue.  Also, I'm using the same SD card tested with the pi 3, FPP v2.6.
Am I missing some settings with the pi zero or does it not have the horsepower to drive a p5 matrix?
Offline Sawdust
  • Kudos: 8
Re: p5 panels with pi zero w
« Reply #1 on: March 16, 2019, 10:27:15 AM »
Not sure I can help your issue, but I do run Pi Zero W in my 2x2 P5 boxes.  I have problems with Pi 3, so I use the Zero's.
Could it be your hardware.  I use Ron Holiday Pi Matrix or POPS Pixel Matrix hats....
Offline ee351
« Reply #2 on: March 16, 2019, 10:52:35 AM »
I don't think it's the hardware, as it's working fine with the pi 3.  How many outputs are you using with the zero?
Offline Sawdust
  • Kudos: 8
« Reply #3 on: March 16, 2019, 12:05:35 PM »
only 2
Offline ee351
« Reply #4 on: March 16, 2019, 01:34:49 PM »
Any ghosting/flickering with your setup?
Offline Sawdust
  • Kudos: 8
« Reply #5 on: March 16, 2019, 02:27:53 PM »
none....
on my 2X2, I run the smaller pixel SMD2121 P5 panels on the Pi Zero's
Larger panels I use the SMD3528 P5 panels and BeagleBones
Haven't tried my SMD3528's on the PI Zero.
No issues.
« Last Edit: March 16, 2019, 02:56:41 PM by Sawdust »
Offline ee351
« Reply #6 on: March 16, 2019, 06:35:41 PM »
The one thing it might be is my home spun matrix adapter that drives the p5 panels directly from the pi's gpio pins.  I ordered one of Ron's pi matrix adapters with the buffered outputs, so we'll see if this makes a difference.
It's crazy, works perfectly with the pi 3, but not the zero.  Perhaps this batch of p5 panels I have just doesn't care for the pi zero.
Offline Sawdust
  • Kudos: 8
« Reply #7 on: March 16, 2019, 11:25:52 PM »
Hope Rons board solves your issue
Offline ee351
« Reply #8 on: March 19, 2019, 11:02:30 AM »
What mode were you using for the zero (stand alone, bridge, or remote)?
Also, were your sequences set for 50ms or 25ms?
Offline Sawdust
  • Kudos: 8
« Reply #9 on: March 19, 2019, 07:13:51 PM »
Ive run Standalone and Remote, and both 25 & 50ms
Offline ee351
« Reply #10 on: March 21, 2019, 07:43:53 PM »
okay, just soldered Ron's matrix board and the same problem persists.  Same issues as above, slow on the zero but fine on the pi 3.  I hope someone can chime in as to what the issue may be.
Offline Sawdust
  • Kudos: 8
« Reply #11 on: March 21, 2019, 09:17:31 PM »
Maybe Panels?  Where did you get your panels?
Slow?  I thought you were having ghosting and flickering
Offline ee351
« Reply #12 on: March 22, 2019, 07:15:59 AM »
I just ordered these p5 panels from Ray Wu about a month ago.
On the zero with GPIO set to 0 (single core) I get ghosting.  It's not terribly prominent but it is there, mainly around letters of text and a slight flicker along the right edge of the panel.  When I set the GPIO to 1 (multi core) the ghosting and flickering goes away but the sequence plays slower.  A 30 second sequence will take about 38 seconds to play through on this setting.  I'm using 25ms sequences so later today I'll convert these to 50ms to see if it makes a difference.
On the pi 3, I have GPIO set to 2; the sequence plays in time and no ghosting.
« Last Edit: March 22, 2019, 07:27:35 AM by ee351 »
Offline dkulp
  • Moderator
  • Kudos: 87
    • KulpLights.com
« Reply #13 on: March 22, 2019, 07:59:42 AM »
You might want to try "0" and then lower the voltage to about 4.8.   For my P5's, I had to lower it just a tad below 5V or I'd get ghosting.
  • Kudos: 214
« Reply #14 on: March 22, 2019, 09:59:09 AM »
When I set the GPIO to 1 (multi core) the ghosting and flickering goes away but the sequence plays slower.  A 30 second sequence will take about 38 seconds to play through on this setting.  I'm using 25ms sequences so later today I'll convert these to 50ms to see if it makes a difference.[/size][/font]
On a single-core Pi Zero driving P5 or multiple P10 panels at 25ms timing may be too much to ask.  There's a reason why we normally recommend using a BBB for driving panels.   Using a Pi is definitely a YMMV situation and has quite a few factors determining whether it will work successfully or not.
