Author Topic: Single Channel DMX AC or DC Switches  (Read 390 times)
Offline nmiller0113
  • Kudos: 9
    • The Miller Lights
« on: July 13, 2019, 12:14:43 PM »
I've pretty much moved all of my stuff away from AC or DC except for a few floods and strobes so I really don't need to have 16 port controllers for them any longer.  What I'd like to do is move to Single Channel DMX AC or DC Switches, so I'm looking for recommendations from the group.  I've seen posts on these before but for some reason cannot find them anywhere.  Thanks in advance for the help!
Online Ebuechner
  • Kudos: 10
Re: Single Channel DMX AC or DC Switches
« Reply #1 on: July 13, 2019, 02:05:31 PM »
3 Channel 5A DMX512 Controlled Relay Switch Kit DIY Converter DMX Dimmer Relay https://www.amazon.com/dp/B00R6DGSAK/ref=cm_sw_r_cp_apa_i_BLJkDb0A15K5Q
Is this what you're looking for?
Offline tbone321
  • Kudos: 50
« Reply #2 on: July 14, 2019, 11:23:41 AM »
Are you looking for a switch or a dimmer?
Offline nmiller0113
  • Kudos: 9
    • The Miller Lights
« Reply #3 on: July 14, 2019, 04:37:17 PM »
I don't need it to do anything other than on or off.  No dimming required.  The 3 channel one would work but I could have sworn I saw someone post a single channel one somewhere.
Offline nmiller0113
  • Kudos: 9
    • The Miller Lights
« Reply #4 on: August 02, 2019, 05:29:33 PM »
No other thoughts here?  Thought there were other options.
  • Kudos: 127
« Reply #5 on: August 03, 2019, 06:26:46 AM »
If you aren't going to be turning the single channel on / off a lot, I'd consider using a USB Relay like:
http://www.icstation.com/icstation-micro-channel-relay-module-control-relay-module-icse012a-p-4012.html
https://youtu.be/8XVLBQZt03Q
These are fully supported in the "other" category of Output devices and work great from Pi or BBB.
They get a DMX channel assigned and directly usable in xLights.
It gets all the power it needs from the USB cable. (the SainSmart relay boards can be more trouble to connect - these ICStation boards are simple and cheap)
Each relay can switch 10 amps, AC or DC. The voltage you apply to the relay is isolated from the FPP controlling it. (up to 250VAC)
« Last Edit: August 03, 2019, 06:48:00 AM by JonB256 »
