Author Topic: Reload older Firmware  (Read 5713 times)
Offline larryk5
« on: July 25, 2019, 08:40:54 AM »
I ordered and received the new receiver card! I then updated the F48 firmware so I can take advantage of the daisy chaining ability. It's nice but now the F48 loses network connect after 30 minutes or so. The F48 screen shows a valid ip and I can run it in test mode and get blinking lights. Even when I can bring up the F48 on the computer the Master Pi doesn't blink the lights in test mode. I had 2.04 on this system and it had been running since November last year!
I tried to change it back to 2.04 but it keeps skipping the sd card Do I need to load the bootloader each time? I didn't think so! Just want to go back to when it worked! Any ideas?
  • Kudos: 126
Re: Reload older Firmware
« Reply #1 on: July 25, 2019, 04:54:01 PM »
The new bootload looks for firmware files with a file type of *.fl2
It may not see the older *.fal  files.
Try going back to F16V3_Player_2_5_b022.fl2
It didn't support smart receivers but was super stable.
https://github.com/dpitts/f16v3_issues/tree/master/f16v3
Offline larryk5
« Reply #2 on: July 25, 2019, 06:33:01 PM »
That file will work for the F48?
Offline David Pitts
  • Kudos: 80
« Reply #3 on: July 26, 2019, 10:28:47 AM »
I will place 2.04 on support page later today. Larry and I are looking into issue now.
  • Kudos: 126
« Reply #4 on: July 26, 2019, 02:58:48 PM »
No, sorry. Didn't notice the "F48" header. Those are F16v3 files.
Offline kwhiteh1
« Reply #5 on: July 26, 2019, 06:10:33 PM »
David, this is same issue I was telling you about.....
Offline jasonash
« Reply #6 on: August 12, 2019, 06:16:01 AM »
I just wanted to follow up on this thread in case anyone else was having this issue. I had installed 2.50 last week and was experiencing lockups after 30 minutes or so with a hard reset being the only fix.
Installing 2.51 fixed my problem and I am no longer seeing lockups. Everything is working as expected now.
The 2.51 firmware I installed is found at:
https://www.pixelcontroller.com/store/index.php?id_cms=10&controller=cms under "Current Firmware"
