Author Topic: 380 pixels w/ power injector and running into multiple issues  (Read 5147 times)
Offline MikelMD
Re: 380 pixels w/ power injector and running into multiple issues
« Reply #30 on: August 05, 2019, 08:47:36 AM »
will do -
Offline MikelMD
« Reply #31 on: August 06, 2019, 03:15:05 PM »
So was able to test and only the first 100 light up!!!  WTF
Offline Poporacer
  • Kudos: 9
« Reply #32 on: August 06, 2019, 03:44:06 PM »
Just to be sure, can you explain how you have it wired and maybe a few pictures of your connections?
Offline Poporacer
  • Kudos: 9
« Reply #33 on: August 07, 2019, 07:14:11 AM »
Also, do you have a multimeter? Can you get voltage readings at the end of the first string, at the injection point at pixel 101 and at the end of the last string, pixel 200?
Offline MikelMD
« Reply #34 on: August 08, 2019, 10:18:06 AM »
Yes I do have a MM and I will test these and get back.
Offline MikelMD
« Reply #35 on: August 18, 2019, 12:03:27 PM »
Ok - after a long and drawn-out battle (and a lot of help from poporacer) the issues:
I did have all of the V+ and G connected at every injection point and when I "connected" the second Power Supply - it fried the 2nd PS - yet it still had enough power to light the F-8!
In the end - for those following the story:
1. V+ and G from Falcon to F-AMP to the first 100 pixels.
2. Cut the V+ after pixel 100.
3. I inject from the second Power supply at pixel 200 and 380 - a nice balance.
Thanks again - poporacer!
