Total Members: 17246
Latest: Saluki86
New This Month: 4
New This Week: 4
Total Topics: 17339
Most Online Today: 3100
Most Online Ever: 8375
Guests: 267
Total: 268
FPP 5.0 Released!
Started by dkulp, August 03, 2021, 05:09:01 PM
FPP 5.0 Released!
The entire FPP team is proud to announce that FPP 5.0 is finally released! This releases is definitely one of the largest releases of FPP with an entirely new UI, new REST API's, changes to how "bridging" is handled, new scheduling capabilities, new effects, and so much more. The entire FPP team has worked very hard to get this ready to be used.
FPP Manual:  https://falconchristmas.github.io/FPP_Manual(5.0).pdf
Enhancements
  • Interface/"Look and Feel" Updates
    • The entire FPP UI has been completely re-written to be more "modern" and mobile friendly. We tried to keep it familiar to FPP users, yet "new and fresh".
    • New "Wizard" on first startup to help configure FPP for the first time
    • Troubleshooting page updated to run commands asynchronously and provide direct links to needed results.
    • Display testing page updated to provide easier adjustments to channel ranges and test settings
    • MultiSync Page updates to provide faster updates and much more information
    • New Privacy settings to prevent callouts to 3rd party sites for vendor logos, statistics, etc...
  • Audio configured to use "dmix" when possible to allow simultaneous audio streams (ex: "Play Media" FPP command can play sound effects from GPIO triggers while show is running)
  • Scheduler Enhancements:
    • Global disable of scheduler to easily disable all scheduled events
    • Allow scheduling of FPP Commands that can execute independently of playlists
    • Allow scheduling of FSEQ files directly so playlists do not need to be created for single sequences
    • Added Preview button to main status page and Scheduler page to preview the upcoming scheduled items
    • Added Dusk/Dawn options to the Scheduler (in addition to SunSet/SunRise). Requires location (Latitude and Longitude) to be set.
  • Pixel Overlay Model Enhancements:
    • Many built in effects for use on Pixel Overlay Models (from WLED project)
    • Automatically create Pixel Overlay Models from descriptions on Pixel Strings and Matrices
  • New Phillips KiNet output support
  • Popup "Run FPP Command" trigger button in footer allowing easy execution of commands from with UI
  • Several enhancements for using FPP in Docker:
    • Auto-set the hostname FPP uses if specified in docker config
    • Auto-set the host description to include the container ID if the description has not been set by the user.
    • Expose the host description setting on the System settings tab when running in docker since the network settings page is not shown.
    • Allow FPP to advertise the external host IP docker is using by setting a FPP_DOCKER_IP environment variable when the container is spawned or by using a setting on the System page
    • Hook up reboot/shutdown actions to kill apache2 when running in docker to trigger the container to shutdown or restart (actual action depends on how the container is configured)
    • Added a sample docker-compose.yml config in docs/samples which uses the FPP image created by dockerBuild.sh or from the docker repo.
  • Pixel String Outputs:
    • Unify the BBB Strings, Pi Pixel Strings, and X11 Pixel Strings pages into a single consistent page
    • Add "End Nulls" option for each virtual pixel string
Major Changes/Incompatibilities
  • Legacy API has been removed. See the API conversion guide for more information
  • "Bridge mode" has been removed. Instead, if e1.31/ArtNet/DDP channel inputs are enabled on the Channel Inputs page, they are always active in both Player and Remote modes. Any incoming channel data will override what is loaded from a sequence. This allows combining pre-rendered sequence data with live data.
  • Retirement of Legacy APIs
  • "Master mode" has been removed. internally, master mode has always been really just player mode with a setting to send out sync packets. This is now reflected in the UI. Thus, FPP now only has two modes: Player and Remote. Either can receive incoming e1.31/ArtNet/DDP data if the Inputs are enabled. A Player can be configured to send sync packets and/or E1.31/DDP/ArtNet data as needed. A Remote will work as before.
  • FPP Events have been changed to "Command Presets". This allows more descriptive names/titles of the events which can make it easier to trigger. There is a now a single trigger channel so users using multiple command channels will need to adjust their configuration.
    • Several stock Command Preset names are called within FPP: FPPD_STARTED, FPPD_STOPPED, PLAYLIST_STARTED, PLAYLIST_STOPPED, PLAYLIST_STOPPING_NOW, PLAYLIST_STOPPING_AFTER_LOOP, PLAYLIST_STOPPING_GRACEFULLY, SEQUENCE_STARTED, SEQUENCE_STOPPED, MEDIA_STARTED, MEDIA_STOPPED
Other updates/changes
  • MQTT - now publishes warnings
  • Additional warnings for common issues like outputting sound to Dummy devices
  • Tons of new REST API's added to support the new UI. Many of the older fppxml.php and fppjson.php calls have been removed. Users using those API's will need to move to the new REST API's. See the API conversion guide for more information
  • Capes/Hats that provide string functionality can remove the "Generic" names in the UI and display the cape names
Upgrade Instructions
It is strongly recommended to do a full "OS Level" upgrade or re-image instead of attempting to upgrade directly from any older FPP version. There are several new features that will not work if an OS level upgrade is not done. There are two ways to do so:
  • Re-image - you can backup your 4.x configuration, create a new image, and restore the configuration.
  • In-place upgrade - this is new and requires you to have FPP 3.6.2 (or 4.0-alpha2) or newer already running on the device. Download the appropriate "fppos" file to your computer. Make sure the file extension is still fppos (some browsers will rename it). Upload it to the "File Manager" on the FPP instance. Then go to the about page. Under the normal "Manual Upgrade", a new Upgrade OS button should appear. Click it and wait a LONG time. When done, it should reboot into 5.0. At that point, go to the Uploads tab of the FPP File Manager and delete the fppos file. Note: In SOME cases, the reboot will fail due to library replacement. In that case, a power cycle may be required to get it back up and running.
Selecting an image
Images can be downloaded from: https://github.com/FalconChristmas/fpp/releases/tag/5.0
For Raspberry Pi series including Pi B, Pi B+, Pi 3, Pi 3+, Pi 4 and Pi Zero use this image
For Beaglebone Black, Beaglebone Green, PocketBeagle, and Beaglebone Green Gateway use this image
ShadowLight8
Thank you! This looks great :)
radiomarsh
Looks awesome. So much more info.  One thing I have found is if I schedule a playlist for 12:00am it sets the play time to 12:00pm.  It does this up until a start time of 1:00 am. I know it's weird but I have some things that start early.
Thanks for all your work on this!
Try using 24 hour time and 00:00 hours.
Quote from: Poporacer on August 04, 2021, 05:21:21 PMTry using 24 hour time and 00:00 hours.
We would be so much better off in many ways if we would abandon our idiotic AM/PM time system and go to 24 hour time (like most of the rest of the world).  Solves lots of confusion!
pixelpuppy
Quote from: k6ccc on August 05, 2021, 08:42:08 AMWe would be so much better off in many ways if we would abandon our idiotic AM/PM time system
AND even more so if we drop the archaic Imperial measurements and embraced the metric system.
Quote from: pixelpuppy on August 05, 2021, 11:55:07 AM
Yep.  That too.
DMJPixel
Quote from: radiomarsh on August 04, 2021, 04:35:29 PMLooks awesome. So much more info.  One thing I have found is if I schedule a playlist for 12:00am it sets the play time to 12:00pm.  It does this up until a start time of 1:00 am. I know it's weird but I have some things that start early.
Quick look at the code and it appears 12:00AM and 12:30AM are stored as "12" and 12:00PM and 12:30PM are stored as "24" (confirmed in schedule.json).  If you are using 12 hour format there is some code that looks at that number to convert to either 12AM or 12PM and I believe that needs a tweak.  I was able to confirm what you posted and also found if I select 12:00PM or 12:30PM it changes to AM.
I will submit an issue with a fix suggestion - folks smarter than me can review and see if I am on the right track to resolve.
And I agree, it it does look awesome!
joeally06
Can you update from 4.6 to 5.0? Or is it a fresh install?
darylc
Quote from: joeally06 on August 05, 2021, 06:37:47 PMCan you update from 4.6 to 5.0? Or is it a fresh install?
Please read the section "Upgrade Instructions" in the first post.
Robocrash
I need a little help here - maybe I'm missing something......
I downloaded and unzipped BBB 5.0.  The unzipped file was named *.img
I renamed the file to FPP-v5.0-BBB.fppos and uploaded to the BBB into the Uploads folder/tab
On the About page,  I see the Upgrade OS field with a dropdown box showing current version - BBB-ver4.5.fppos.
The new file:  FPP-v5.0-BBB.fppos    does not appear on the dropdown box.
Was it supposed to be uploaded into the Images folder/tab?
Quote from: Robocrash on August 06, 2021, 06:54:17 AMThe unzipped file was named *.img
That is NOT how you do it, If you want to use the fppos upgrade, you have to download the fppos file. not the .img file. I am not sure why you are renaming it?
Robocrash
That's what I was missing.  I downloaded the file linked on the main post instead of using the link to the downloads page.
thanks for the help.
SCUBA
same playlists and same files on two different 3B+ RPI.
Difference is in the version of FPP.
4.6.2 and 5.0.1
below are screen vids of the status pages: Screen Recording.... is the FPP 5.0.1 and Fpp recording 461 a is the FPP4.6.1.
Please note that the 4.6.1 will play from the "lead in" thru to "Main Playlist" while in FPP 5 goes into idle mode and stops playing.  This will occur even if I remove the "Let it go" sequence. I've included the FPPD.log in the next post.
SCUBA
FPP install script on Ubuntu, no video by ee351
May 08, 2026, 05:58:33 PM
Add Multiple items to a playlist at once? by crookedpriority
May 07, 2026, 12:39:25 PM
FPP Remote Audio by csmith
May 06, 2026, 08:51:27 AM
FPP 9.5 won't remember audio out device on reboot. by csmith
May 05, 2026, 06:05:07 PM
Max number universes on FPP? by Santacarl
May 05, 2026, 05:04:01 PM
Moving Head Color by dspenman
May 03, 2026, 12:00:10 PM
Kulp K32A-B Differential Receiver Flickering by Yffej
April 30, 2026, 07:59:05 PM
F16v5 Color Order by MikeKrebs
April 27, 2026, 08:36:10 PM
Pi-nightly? by SCUBA
April 23, 2026, 02:54:31 PM
Leviton Decora Smart Plugin for FPP (beta) by Bwinter
April 22, 2026, 05:13:59 PM
