Author Topic: Odd Sized Matrix  (Read 379 times)
Offline rdebolt
    • Christmas in Boise
Odd Sized Matrix
« on: October 28, 2014, 08:08:48 AM »
For the last 2 years I have been trying to make my roof a matrix. Last year was a nightmare with the Technicolor nodes so I had to take it down and go back to regular leds. This year I have my replacement nodes going up and so far so good. When I am done I will have 65 strings of different lengths in most of the strings to adjust for my roof. My question is.... How will I set this up as a matrix as it is not a square or rectangle? My Main roof is my "Target" matrix and has 33 Strings of different lengths. My goal is to have something running for Halloween, but I am not sure that I can pull that off.
What I should probably add is I want to make pumpkin singing by Friday.....Could use help with that as well!!!! LOL  ;)
[attachment deleted by admin]
« Last Edit: October 28, 2014, 08:17:45 AM by rdebolt »
Online smeighan
  • Kudos: 11
    • Nutcracker123
Re: Odd Sized Matrix
« Reply #1 on: October 28, 2014, 09:12:16 AM »
Make a custom model for it. all matrix objects, singing faces should all work.
the other choice is a vertical matrix , make vertical the longest string length. This method requires having the string start address set correctly in the controllers. multiples of the longest length
Sean
Offline rdebolt
« Reply #2 on: October 28, 2014, 01:21:10 PM »
Thanks Sean, I will try that tonight and see how it goes!
