Author Topic: 3.1.0 xlights will allow meging LSP sequences  (Read 957 times)
Offline smeighan
  • Kudos: 11
    • Nutcracker123
« on: August 07, 2013, 10:49:25 PM »
Dave Pitts;
the 3.1.0 release gives you what you requested.
Sequence part of your megatree in ls and we will now allow you to not have it overridden.
If you created a LSP effect on your tree for teh first 30 seconds, mark the first 30 seconds fo rows with the effect "none,none". When exporting we will not override the original values.
You wanted it, Frankr gives it to you
thanks
sean
Sean
  • Kudos: 76
Re: 3.1.0 xlights will allow meging LSP sequences
« Reply #1 on: August 07, 2013, 11:18:29 PM »
Thanks Frank. Sounds great.
Offline Steve Gase
« Reply #2 on: August 08, 2013, 01:42:37 AM »
this is great!
  • Kudos: 124
« Reply #3 on: August 09, 2013, 07:41:42 PM »
Any reason it won't also work for LOR (or Vixen)?
If so, thanks!!
Offline Frankr
    • Rocklin Lights
« Reply #4 on: August 09, 2013, 08:17:19 PM »
It works with vixen or LOR just fine. It also works within xLights.
