Author Topic: USB WiFi Adapter  (Read 1597 times)
aich75013
  • Guest
USB WiFi Adapter
« on: August 12, 2013, 02:06:44 PM »
I am just wondering, if using a USB WiFi adapter on the Raspberry Pi, how do you tell it which network to connect to and the network password?
I am trying to figure out how this all connects together if I am using am EtherDongle.  I would have an ethernet cable between the Pi and the EtherDonge, so I would need to use a USB adapter for wireless, right?
Offline MyKroFt
  • Kudos: 57
Re: USB WiFi Adapter
« Reply #1 on: August 12, 2013, 05:09:08 PM »
The way I would do it is connecct the pi and ethd to your local lan.  The the pi will get a dhcp ip and will be happy.  I am working on the network config page now as we speak er type. .
Sent from my Samsung Galaxy S4 using Tapatalk 2
Offline Steve Gase
« Reply #2 on: August 12, 2013, 06:53:54 PM »
But with wireless, it becomes difficult to connect to the local lab -- selection of SSID, password, etc.
I think the answer is that you need to connect a USB keyboard/mouse and display, then you can log into the Linux OS to set the network configuration.
Offline MyKroFt
  • Kudos: 57
« Reply #3 on: August 12, 2013, 08:22:36 PM »
no, it defaults to DHCP, I am working on the network config page now.
You will be able to change eth0 and wlan0 to either static or dhcp, and wlan0 will have a place for your SSID and password.
Myk
