Author Topic: (Solved) Model Colors off?  (Read 838 times)
Offline rdebolt
    • Christmas in Boise
« on: December 17, 2014, 08:28:48 PM »
Can someone tell me why my models that are set up exactly the same are off on colors? For example I have 4 arches. If I do a color wash on all 4 (built a whole house model for them) Arch 4 is a different color than the other 3. I have made a screen capture with an example. I have other models doing this as well so I am not sure what the problem is.
Thanks,
Roger
https://www.youtube.com/watch?v=Ae9xtudtiAQ&feature=youtu.be&hd=1
« Last Edit: December 19, 2014, 09:06:52 AM by rdebolt »
Offline smeighan
  • Kudos: 11
    • Nutcracker123
Re: Model Colors off?
« Reply #1 on: December 17, 2014, 08:42:45 PM »
do the lights play correctly? Is this a whole house model?
please list the start channel of the 4 arches.
if you divide each do they end in .33333?
we have had this discussion
NUTCRACKER tab , plays colors correctly. Doesnt care about start channel
PREVIEW tab, will only display color correctly if channels are in multiples of 3
Actual lights, play color correctly.
we will work he PREVIEW tab after new years
Sean
Offline rdebolt
« Reply #2 on: December 17, 2014, 08:51:06 PM »
Sean yes they are built in a whole house model as noted in my first post. I thought that if they were built in a whole house model that we did not need to worry about the multiples of 3??
Thanks,
Roger
Offline rdebolt
« Reply #3 on: December 17, 2014, 09:09:38 PM »
Am I wrong about that?
Roger
Offline smeighan
  • Kudos: 11
    • Nutcracker123
« Reply #4 on: December 17, 2014, 10:49:17 PM »
Do they display correctly on the actual lights and in the nutcracker tab?
  • Kudos: 68
« Reply #5 on: December 18, 2014, 07:45:09 AM »
In theory no, but in actual practice I think so.   Do you have one model or four models.  I found it much cleaner and simpler to have just one model that defines all 4 arches.
Offline rdebolt
« Reply #6 on: December 18, 2014, 09:57:56 AM »
Sean, The actual lights look like the preview tab, so no the light do not play correctly. In the sequencing preview tab yes they look ok, but I know that the Sequence preview is not an actual output. So the Preview\playback tab look exactly like my arches in the yard. You can see from the sreen shot that I took.
Thanks,
Roger
Jim, Yes I have 4 models for my arches, then I built a "Whole House Model" off of those 4 models. I may try and just make 1 model tonight.
Thanks,
Roger
Offline rdebolt
« Reply #7 on: December 19, 2014, 08:55:35 AM »
Well I found my problem. I had a channel overlap on my 4th arch to one of my other elements.
Thanks for the help guys!
Roger
