Author Topic: Help programming SSC  (Read 2161 times)
Offline dgreen
« on: September 11, 2013, 05:34:23 PM »
Hey guys,
I am having trouble programming my SSCs V3 with Davids firmware.
it is something I am doing wrong because they are working with the DILA firmware.
Here is how I am programming.
1.   I connect my pickit 3 to the computer and then to the SSC, the program jumper is on
2.   Then I open up MPLAB
3.   I choose configure/select device
4.   Then on the dropdown I choose PIC24FJ32GA002 and click ok
5.   Then I select programmer/select programmer/pickit3. It reads the device with no errors.
6.   Then I choose file/import and browse to the hex in the downloads section.
7.   Then I click program. It completes with no errors
8.   Now I disconnect the pickit3 programmer and hook up a string of lights.
9.   I now open up the smart string grouping program I downloaded here (jumper is still on)
10.   I type a description, put in a new start channel, set the node count, leave device as string.
11.   Finally I click program all SSC on hub and click program. Then close the program.
12.   Now I open Xlights and test. I get nothing, cant get the lights to come on.
13.   If I remove the jumper on the SSC then they all turn on white and I have no control
Any ideas what I am doing wrong?
Like I said, this works with the other firmware so it is something I am doing.
Thanks.
  • Kudos: 76
Re: Help programming SSC
« Reply #1 on: September 11, 2013, 06:03:28 PM »
With SSCv3 jumper will always be off. It will never be on.
Offline dgreen
« Reply #2 on: September 11, 2013, 06:08:20 PM »
ok, i dont know why i thought it had to be on.
So i remove the jumper and reran the smart string grouping program just as i did before.
Then i open Xlights and click on test/all channels and output to lights.
as soon as i click output to lights they all turn on white.
  • Kudos: 76
« Reply #3 on: September 11, 2013, 06:49:55 PM »
When you do the programming with Smartstring Grouping the string should turn Rainbow color when it programs successfully. Did you see this.
Offline dgreen
« Reply #4 on: September 11, 2013, 06:56:49 PM »
No, the lights never come on when programming.
Does that mean the .hex didnt take?
Offline mms
« Reply #5 on: September 12, 2013, 06:49:45 AM »
Did you happen to program the string for hybrid mode?  In my experience, if the lights are going all white on a test all that's usually what the case is.  Unselect the hybrid channels and try a chase.
Also, did you "power cycle" the SSC after you programmed it?
Otherwise it looks like you did everything correctly.
Offline JerryPlak
« Reply #6 on: September 12, 2013, 08:37:31 AM »
for  dgreen,
After reading list on #10. I type a description, put in a new start channel, set the node count, leave device as string,
On my setting up I end up using Flexible strip (DLA 1809)  for the device type:
I found the same thing that the SSC all turn on white.. so I re program my SSC using Flexible strip (DLA 1809)  for the device type:
now got Rainbow color when it programs successfully ;D
Jerry Plak
Offline Kevin
    • Colorado Christmas
« Reply #7 on: September 12, 2013, 09:02:26 AM »
Do not use the MPLAB IDE program.  Use the PICKit 3 version 1 stand alone program to flash the firmware on SSCs, Etherdongle, and all Falcon products. here is a link to it:
http://favstar.fm/users/MicrochipTech/status/61119098477740032
Kevin
Kevin
Colorado Christmas
Offline dgreen
« Reply #8 on: September 12, 2013, 05:16:19 PM »
Thanks guys, that fixed it!!!
I guess it was in the programming of the .hex file.
it works now even when set to string.
Thanks again.
  • Kudos: 117
« Reply #9 on: September 12, 2013, 08:14:55 PM »
Has anyone ever looked at why MPLAB does not program PICs properly?
I've heard to not use it for years, but I don't know PIC programming well enough to tell anything about why it fails.
