Author Topic: RGBMatrix Output Connections for BBB?  (Read 941 times)
Offline drlucas
« on: March 02, 2015, 04:55:54 AM »
In the online help for the FPP it shows the pin outs for the Raspberry Pi and the wiki has a good write up on how to install the BBB, but is there a way to connect the BBB to a panel without a cap and just using male to female jumper wires?
LED Panel   Raspberry Pi
GND - Ground   Pin 3 - GND
R1 - Red 1st bank   Pin 11 - GPIO 17
G1 - Green 1st bank   Pin 12 - GPIO 18
B1 - Blue 1st bank   Pin 15 - GPIO 22
R2 - Red 2nd bank   Pin 16 - GPIO 23
G2 - Green 2nd bank   Pin 18 - GPIO 24
B2 - Blue 2nd bank   Pin 22 - GPIO 25
A - Row address   Pin 26 - GPIO 7
B - Row address   Pin 24 - GPIO 8
C - Row address   Pin 21 - GPIO 9
D - Row address   (Not Used for 32x16 panels
OE - Neg. Output Enable   Pin 3 - GPIO 2
CLK - Serial Clock   Pin 5 - GPIO 3
STR - Strobe row data   Pin 7 - GPIO 4
Ryan
  • Kudos: 209
Re: RGBMatrix Output Connections for BBB?
« Reply #1 on: March 02, 2015, 08:38:18 AM »
I think you should be able to do this with the LEDscape code we are using, but I haven't looked at a pinout yet.  You will also be able to drive ws281x pixels the same way if they are able to handle the lower voltage level output from the BBB without having a level shifter in the middle.
Offline drlucas
« Reply #2 on: March 02, 2015, 05:27:18 PM »
Well my octoscroller boards are going in on Wednesday by the looks of it, so I assume in about 2 weeks they will arrive here.  I'll see if I can make anysense of the traces - mind you I don't think I have any spare transceivers, so will have to put in a small mouser order one day soon too...unless they aren't needed.
Also found this LEDscape pin assignments.csv
Code: [Select]
Signal,Header/Pin,Port
S00,P8-18,GPIO2_01
S01,P8-17,GPIO0_27
S02,P8-15,GPIO1_15
S03,P8-16,GPIO1_14
S04,P8-14,GPIO0_26
S05,P8-13,GPIO0_23
S06,P8-11,GPIO1_13
S07,P8-12,GPIO1_12
S08,P8-10,GPIO2_04
S09,P8-09,GPIO2_05
S10,P8-07,GPIO2_02
S11,P8-08,GPIO2_03
S12,P9-41,GPIO0_20
S13,P9-30,GPIO3_16
S14,P9-27,GPIO3_19
S15,P9-26,GPIO0_14
S16,P9-25,GPIO3_21
S17,P9-24,GPIO0_15
S18,P9-23,GPIO1_17
S19,P9-22,GPIO0_02
S20,P9-21,GPIO0_03
S21,P8-27,GPIO2_22
S22,P8-28,GPIO2_24
S23,P9-18,GPIO0_04
S24,P9-17,GPIO0_05
S25,P9-16,GPIO1_19
S26,P9-15,GPIO1_16
S27,P9-14,GPIO1_18
S28,P9-13,GPIO0_31
S29,P9-12,GPIO1_28
S30,P9-11,GPIO0_30
S31,P8-26,GPIO1_29
« Last Edit: March 02, 2015, 05:53:39 PM by drlucas »
