Author Topic: unable to start fppd on bbb  (Read 3636 times)
  • Kudos: 214
Re: unable to start fppd on bbb
« Reply #15 on: April 13, 2015, 09:28:57 AM »
I will try to reproduce the scrolling issue tomorrow.
The problem with the master branch is reproducible every time.  Should I do a clean load and then change to master?
If you use the latest install script, it automatically uses master instead of the BBB branch which is no longer being updated.
https://raw.githubusercontent.com/FalconChristmas/fpp/master/SD/FPP_Install.sh
Offline egenoup
« Reply #16 on: April 13, 2015, 01:02:39 PM »
I did not get a chance to play with it this weekend, but I will try tonight.  Thanks for the info on the Master/BBB branch.
Charles
Offline egenoup
« Reply #17 on: April 14, 2015, 11:28:00 AM »
Reloading from scratch and using the new installation script worked.  Tonight I will test the Scrolling issue I was seeing when I misconfigured the panels to see if it is still there or just a figment of my imagination...
Charles
