Author Topic: Wiring with shielded cable  (Read 767 times)
Offline Jeffl
  • Kudos: 4
    • Christmas In Brandon
« on: August 29, 2015, 05:09:57 PM »
I bought this cable to wire up some ws2811 pixels with either with a F16v2, Hub/uSC or run between pixels props.  Not sure the Shielded was a good idea but I have it so the question is what should I good with the extra bare wire if anything?
http://www.tektel.com/PLC4504.html?SearchOffset=
Offline corey872
  • Kudos: 16
    • Link to the sale...
Re: Wiring with shielded cable
« Reply #1 on: August 29, 2015, 06:26:44 PM »
Well... it depends...
For most any normal condition, I don't think you'd have to do anything with it.  I guess if you wanted to, you could tie it to ground to provide a little shielding and a little stronger ground path...assuming adding extra capacitance to the wire doesn't cause some other issue...in that instance, you might want it floating.
I put a little more info in this other response:
http://falconchristmas.com/forum/index.php/topic,2682.msg29113.html#msg29113
Corey
Offline Jeffl
  • Kudos: 4
« Reply #2 on: August 30, 2015, 09:28:34 AM »
Thanks for the tip. For me and others that may use this cable.  The funny part is late last night I started digging through my pre order shipment and found a bunch of extension cables that I planned to use to for this task.  Memory got the best of me so I'm not sure I'm going to have a use for this now. :)
