Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
The F16V3 E131 Controller is now available in the store!! -
http://pixelcontroller.com/store
Home
Recent Posts
Help
Search
Wiki
Store
Chat
Calendar
Downloads
Login
Register
Help with development and website costs
Falcon Christmas
Other Controllers and Hardware
General Hardware
Options for mounting power supplies into CG1500
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Options for mounting power supplies into CG1500 (Read 1504 times)
Jeffl
Supporting Member
Kudos: 4
Just remember. Wireless is nice. Copper is king!
on:
September 25, 2015, 08:22:40 AM »
I have some DIYLEDExpress 12v power supplies that I need to mount into some older model CG1500 cases. I know there are plastic shelves that you can but but I'm sure there are cheaper methods.
I have some ideas but does anyone have any suggestions or photos of how they did it that worked well?
Logged
toozie21
Sr. Member
Kudos: 0
Re: Options for mounting power supplies into CG1500
Reply #1 on:
September 25, 2015, 08:44:58 AM »
How about a piece of scrap acrylic (or similar material) from a big box store. You can then drill the holes where you need it and screw everything in place.
Logged
~Jason
www.tooz.us
Jeffl
Supporting Member
Kudos: 4
Reply #2 on:
September 25, 2015, 09:47:47 AM »
Thanks. I think the Ace hardware in town sells it cut to fit. I'll check that out. Now I just need to see what screw sizes it takes. The power supply has mounting holes, some of which the circuit board is behind. Not the greatest design feature.
Logged
toozie21
Sr. Member
Kudos: 0
Reply #3 on:
September 25, 2015, 09:58:13 AM »
I believe that they are #8 sized (at least based on this:
http://www.diychristmas.org/vb1/showthread.php?2433-Two-Power-Supplies-in-a-CG-1500
Yeah, the nut locations leave something to desired. I think I only used 2 or 3 of the mounting points so I didn't risk ruining/shorting anything.
Logged
JonB256
Supporting Member
Kudos: 117
Reply #4 on:
September 25, 2015, 09:58:15 AM »
I use Zip ties to hold the power supply to the mounting board if the threaded holes are not convenient.
Logged
mikewlaymon
Newbie
Kudos: 0
Reply #5 on:
September 25, 2015, 10:11:34 AM »
Industrial strength velcro on the back? (what I did with one of mine)
Logged
Jeffl
Supporting Member
Kudos: 4
Reply #6 on:
September 25, 2015, 10:19:53 AM »
Thanks. This is what I needed.
Logged
Jeffl
Supporting Member
Kudos: 4
Reply #7 on:
September 25, 2015, 07:43:02 PM »
One done. An F8 and 30amp supply. I Mounted the power supply with 3 #8 screws. Couldn't get 4 because of the holes in the case and I couldn't get it centered where I wanted but it worked fine. The screws went in just far enough but not too far before they got tight.
For the controller I used 6x32 5/8 screws and 1/4 length of 1/4 water line as a standoff. I'm happy with the outcome.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Falcon Christmas
General Hardware
