Author Topic: Static ip address for wireless falcon pi  (Read 1902 times)
Offline sirloinofbeef001
  • believe in miracles
« on: October 20, 2013, 07:21:55 PM »
I am wondering how to specify a static ip address for the edimax wireless card.
Its a wonderful life.
Offline neilric99
Re: Static ip address for wireless falcon pi
« Reply #1 on: October 20, 2013, 09:23:08 PM »
I have not tried this but it would be a setting in the /etc/network/interfaces file
sudo nano /etc/network/interfaces
iface wlan0 inet static
  address 192.168.100.100
  netmask 255.255.255.0
  gateway 192.168.100.1
  wpa-ssid "your wireless network"
  wpa-psk "your password"
« Reply #2 on: October 21, 2013, 10:06:24 AM »
Ia there a way to set a static IP for the edimax from the rasberry?
Offline neilric99
« Reply #3 on: October 21, 2013, 10:56:27 AM »
that instruction was from when you connect to your Raspberry Pi and access it via putty/ssh or from the console.
« Reply #4 on: October 25, 2013, 11:09:04 AM »
Its seems that when you turn off the pi, it needs to establish an IP address so its looking for one from the router when I turn it on again.. I have an older Linksys. Does the edimax ask for a designated IP range that I can set on the lynksys so I don't have to set it for it?
Offline MyKroFt
  • Kudos: 57
« Reply #5 on: October 25, 2013, 04:35:35 PM »
most routers will let you map a MAC address to a specific ip during DHCP - you just need to figure out your wireless MAC address and set it to a specific ip in your router.
have you also tried accessing http://fpp in your browser - most dhcp servers will set fpp to the current ip assigned to it
Tony
