Author Topic: directionality is not retained with controller settings  (Read 1057 times)
Offline Steve Gase
« on: October 23, 2013, 09:22:09 PM »
Small problem, just thought I'd mention it.
As I create multiple controller definitions, I want every other controller to be have reverse (backward) directionality.  As I set up arches, I want the wires to come together in cable runs.
anyway... within the Falcon SSC utility, as I click on one controller definition after another the forward/backward selection shows whatever I last clicked on, and it does not show the last value set for that controller.  also, the direction does not get saved in the config file to be loaded later with the other data.
Offline Steve Gase
Re: directionality is not retained with controller settings
« Reply #1 on: October 23, 2013, 09:24:40 PM »
I just read pk's posting... I think the issue is not just saving.  but I'll check the latest drop.
Offline Steve Gase
« Reply #2 on: October 23, 2013, 09:40:11 PM »
the download is broken (for 1.0.10)
c
  • Kudos: 76
« Reply #3 on: October 23, 2013, 10:28:45 PM »
It is fixed now.
Offline Steve Gase
« Reply #4 on: October 24, 2013, 12:37:05 AM »
great!  everything is working as expected now.
download is working, loading the config works, and selection of controllers shows the current value.
thanks!
question: did anything change in the firmware to cause me to update my controllers?
  • Kudos: 76
« Reply #5 on: October 24, 2013, 12:42:46 AM »
thanks!
No change in the firmware.
