Author Topic: Rasclock and FPD  (Read 2883 times)
Offline rdebolt
    • Christmas in Boise
Rasclock and FPD
« on: October 24, 2013, 08:49:14 AM »
Ok so I am sure another stupid question, but if the Rasclock goes on the ribbon pins, is there an adapter to still connect the FPD. How would you set up both?
Offline Steve Gase
Re: Rasclock and FPD
« Reply #1 on: October 24, 2013, 09:48:24 AM »
I've reached the same point.
I thought there was some consideration on how to solve that with another small board.
I'm wondering as well if I could add another connector to the ribbon cable so that the FPP, FPD and the RASCLOCK are all connected with that common cable.
Offline JerryPlak
« Reply #2 on: October 24, 2013, 10:57:55 AM »
Jerry Plak
Offline rdebolt
« Reply #3 on: October 24, 2013, 11:25:28 AM »
That looks promising Jerry!
Offline MyKroFt
  • Kudos: 57
« Reply #4 on: October 24, 2013, 11:26:05 AM »
You install the expansion header on the fpd.  It is optional.  So it will plug into the fpd board and not on the pi
Offline rdebolt
« Reply #5 on: October 24, 2013, 11:27:59 AM »
Part Number or link?
Offline MyKroFt
  • Kudos: 57
« Reply #6 on: October 24, 2013, 11:29:45 AM »
Would have to look it up but it is just a 2 row header next to the ribbon cable connector
Offline MyKroFt
  • Kudos: 57
« Reply #7 on: October 24, 2013, 11:47:10 AM »
P2 is the header I am talking about
Tony
  • Kudos: 76
« Reply #8 on: October 24, 2013, 12:03:47 PM »
I have not spec'd the part but it would be nice to get an extra long male header there so RasClock does not rest on the ribbon cable coming over from Pi on P1. The Rasclock is long enough and would need to rest on cable if a longer header is not used to raise it up some. If anyone wants to look for appropriate part that would be great.
Offline Materdaddy
  • Kudos: 10
    • Christmas On Quiet Hills
« Reply #9 on: October 24, 2013, 03:58:17 PM »
don't know if this will work ....http://www.abelectronics.co.uk/products/3/Raspberry-Pi/15/RTC-Pi-Real-time-Clock-Module
Note that this RTC will NOT work without modification on the FPP image.
Mike only put support for the Rasclock which is based on a pcf2127a chipset.  The one you linked to here is based on the ds1307 which uses a different driver.
Offline JerryPlak
« Reply #10 on: October 24, 2013, 04:06:45 PM »
Mat thos good to know :-)
Send from my Galaxy III
  • Kudos: 122
« Reply #11 on: October 24, 2013, 06:04:17 PM »
A little bit of modification and the Rasclock could go UNDER the Pi.
Or - since I'm using a computer ribbon cable (IDE) with 3 connectors (because I just didn't see a reason to cut it off, could the Rasclock just plug into the correct 6 pins of the extra end?
(yes, I know it is "female to female" as it exists, but I could easily find 6 pieces of metal similar to those pins, or just buy a 6 pin Male to Male adapter from Mouser)
Offline MyKroFt
  • Kudos: 57
« Reply #12 on: October 24, 2013, 06:09:35 PM »
If someone wants to use this non RasClock RTC chip, get me the module driver for it and I will add support to select which RTC chip you want in the timeconfig page
Tony
Offline MyKroFt
  • Kudos: 57
« Reply #13 on: October 24, 2013, 06:11:15 PM »
here is a link http://www.adafruit.com/products/1112 for a stacking header to get the RasClock above the ribbon connector
Tony
  • Kudos: 122
« Reply #14 on: October 24, 2013, 07:24:56 PM »
Mykroft, do you know of any reason that you can't have the Rasclock and the FPD connected at the same time?
Doesn't the Pi just query the Rasclock on boot up? or does it periodically check the time?
