Author Topic: Rasclock and FPD  (Read 2985 times)
Offline MyKroFt
  • Kudos: 57
Re: Rasclock and FPD
« Reply #15 on: October 24, 2013, 07:59:29 PM »
It only polls it at boot up - the Optional expansion header was added so it could be plugged into the FPD
Tony
Offline Materdaddy
  • Kudos: 10
    • Christmas On Quiet Hills
« Reply #16 on: October 24, 2013, 08:18:24 PM »
Mykroft, do you know of any reason that you can't have the Rasclock and the FPD connected at the same time?
Doesn't the Pi just query the Rasclock on boot up? or does it periodically check the time?
I believe the Rasclock is only queried on boot.  The time is stored to it if you manually set the time in the FPP ui as well.
Online JonB256
  • Kudos: 124
« Reply #17 on: October 24, 2013, 08:45:49 PM »
... the Optional expansion header was added so it could be plugged into the FPD
Tony
Is the "optional expansion header" the 2x9 pin area labeled as P2 ?? (just below the 2x13 header for the ribbon cable).
My FPD is working at the moment and attached in a case, so I can't flip it over to verify.
  • Kudos: 77
« Reply #18 on: October 24, 2013, 08:51:44 PM »
Yes P2
Online JonB256
  • Kudos: 124
« Reply #19 on: October 25, 2013, 07:00:05 AM »
Because I just can't stand to hear everyone talk about the Rasclock, I ordered one. Soon, I will rule the world!
Online JerryPlak
« Reply #20 on: October 25, 2013, 07:05:22 AM »
O-NO not that  ;) but just one Rasclock hold on I only have one.. maybe will need to order another Rasclock and not looking to rule the world!! 8)
Jerry Plak
Offline Steve Gase
« Reply #21 on: October 25, 2013, 07:15:20 AM »
If all pi are connected, only one ras clock should be needed when all is said and done.
