Author Topic: Current Version 1.0.10  (Read 2009 times)
Offline Kevin
    • Colorado Christmas
« on: May 03, 2013, 10:08:04 AM »
The Falcon Smart String Utility is a firmware and software upgrade for the original v1 and v2, and the modified v2 of the smart string controllers.  The firmware and software allow you to do grouping and removes the 128node limitation.  However you must watch the amp draw.  Use at your own risk.  Will not work on v4 of the SSC.
If you are using a modified SSC v2 the jumper must be off to be used in the run mode.
With an unmodified SSC the jumper must be on for the SSC to be in the run mode.
Version 1.0.10 will automatically adjust the pixelnet channels above 4096 to their correct single board numbering order.
« Last Edit: October 23, 2013, 12:22:16 AM by David Pitts »
Kevin
Colorado Christmas
