Author Topic: Using the FMT212R radio  (Read 1136 times)
Online JonB256
  • Kudos: 124
« on: October 31, 2013, 04:52:48 AM »
 Materdaddy, in chat you said "I have some code in linux that changes the frequency of the FMT212R! W00T!!!"
So I looked it up. USB controlled from PC or Pi ??
RDS capability and about $120 from AliExpress?
Tell me (us) more about what you've been doing with this.
Offline Materdaddy
  • Kudos: 10
    • Christmas On Quiet Hills
Re: Using the FMT212R radio
« Reply #1 on: October 31, 2013, 08:57:19 AM »
I actually bought mine through a group buy last year for $100.
Two of the usual "DIYC" vendors list them, but both are out of stock:
http://radiant-holidays.com/radiant_holidays/index.php?main_page=product_info&cPath=4&products_id=70
http://www.diyledexpress.com/index.php?main_page=product_info&cPath=21&products_id=192
I found out that I could configure it in windows, save the configuration to EEPROM and plug it into a linux machine and the audio portion shows up as a generic USB/Audio device, meaning I can switch the output of my linux machine and transmit the audio.
I originally bought this not even knowing it might be controllable in linux.  Once I got it, the eventual plan was to use it in my display, but I still didn't know it would be possible without TONS of effort.  A month or two ago Gizmo posted on DIYC that there was source code available for various versions/similar devices using the same chip, etc. and he was working on stuff for Vixen 3.  I was able to get some links and downloaded a few repositories.
One was this repository called fmstick that uses Qt and is cross-platform: https://github.com/piratfm/fmstick
Pros:
  * Cross-platform
  * Compiled & worked (mostly) right out of the repository on my linux machine
  * Supports tons of features for the device (setting RDS, changing all sorts of parameters, reading/writing EEPROM, etc.)
Cons:
  * GUI (this is a con for the PI)
  * Very unstable - crashes a lot
There were also posts from drlucas on DIYC and we exchanged a few PMs.  He found a CLI version, but it wasn't very useful because it was based on the USB device/I2c hookup that isn't used in this VAST, even though it was a similar chip: http://tipok.org.ua/node/29
Pros:
  * CLI, what we want for our use-case
Cons:
  * Didn't work, even after changing the usb product ID and vendor ID
After a couple PMs with drlucas and digging through the fmstick source, generating logging using the compiled fmstick, I was able to see that all the "guts" happen in fmtx.c which is the main API to control the device so I got that compiling separate from fmstick and started tweaking things.
Currently the only thing my code does is change the transmit frequency, but I don't store it because I don't want to screw up the eeprom.  I need to investigate the order of operations to the device based on the (mostly) working fmstick application and go from there, but the good news is, I have successfully been transmitting and changed frequency.
Here's what I have so far:
https://github.com/Materdaddy/vastfmt
