Author Topic: F16v1.03 setup in XL/NC  (Read 1260 times)
Offline FireMedic4Christ
« on: December 02, 2015, 08:15:42 PM »
My setup:  RPi -> FPD -> F16v1.03 x3 which programmed successfully.
All ports on the FPD setup to output pixelnet and I am able to run test patterns via the FPP.
XL/NC setup has 28 universes as E 1.31. Selecting all channels on the test page and running a test does nothing. Output to lights set. FPD in bridge mode.
Am I correct to set the controllers up as E 1.31 even though I am using pixel net?
« Last Edit: December 02, 2015, 09:24:06 PM by FireMedic4Christ »
Brian
Offline sirloinofbeef001
  • believe in miracles
Re: F16v1.03 setup in XL/NC
« Reply #1 on: December 02, 2015, 09:07:25 PM »
Did you click the lights on tab on the right side of the test page? And yes, E1.31 is what I do.
Its a wonderful life.
  • Kudos: 122
« Reply #2 on: December 02, 2015, 09:10:07 PM »
My setup:  RPi -> FPP -> F16v1.03 x3 which programmed successfully.
All ports on the FPP setup to output pixelnet and I am able to run test patterns via the FPP.
Do you mean FPD (falcon player dongle) ????
Is your RasPi setup in Bridge Mode or Standalone or Master?
« Reply #3 on: December 02, 2015, 09:22:20 PM »
yes, bridge mode on FPD
yes to output to lights set.
  • Kudos: 122
« Reply #4 on: December 02, 2015, 09:59:48 PM »
Do you see data numbers changing on the FPP status page?
« Reply #5 on: December 02, 2015, 10:08:22 PM »
No data numbers changing.
Don't know if it is related, but when I stop the test the lights remain on. I have to stop and restart the FPPD to get the lights to go out.
