Author Topic: Release of Falcon Pi Player (FPP) Alpha 0.1.2 - Required Update  (Read 1797 times)
Offline MyKroFt
  • Kudos: 57
« on: November 01, 2013, 05:24:07 PM »
Note:  Now that Halloween is over - This is a required update - there are changes under the hood to support the soon to be released updates.  This version is also required for any support - update to this ASAP.
Preparing your SD card for the FPP on your Raspberry Pi
In order to use your Raspberry Pi the the Falcon Player Software, you will need to install an Operating System (OS) onto an SD card. An Operating System is the set of basic programs and utilities that allow your computer to run; examples include Windows on a PC or OSX on a Mac.
These instructions will guide you through installing a recovery program on your SD card that will allow you to easily install the OS and to recover your card if you break it.
1. Insert an SD card that is 4GB or greater in size into your computer
2. Format the SD card so that the Pi can read it
  a. Windows
    i. Download the SD Association's Formatting Tool1 from https://www.sdcard.org/downloads/formatter_4/eula_windows/
    ii. Install and run the Formatting Tool on your machine
    iii. Set "FORMAT SIZE ADJUSTMENT" option to "ON" in the "Options" menu
    iv. Check that the SD card you inserted matches the one selected by the Tool
    v. Click the Format button
  b. Mac
    i. Download the SD Association's Formatting Tool from https://www.sdcard.org/downloads/formatter_4/eula_mac/
    iii. Select Overwrite Format
  c. Linux
    i. We recommend using gparted (or the command line version parted)
    ii. Format the entire disk as FAT
3. Download the FPP Alpha New Out Of Box Software (NOOBS) from https://sourceforge.net/projects/falconpiplayer/files/latest/download?source=navbar
4. Unzip the downloaded file
  a. Windows Right click on the file and choose Extract all
  b. Mac Double tap on the file
  c. Linux Run unzip [downloaded filename]
5. Copy the extracted files onto the SD card that you just formatted
6. Insert the SD card into your Pi and connect the power supply
Your Pi will now boot into NOOBS and will select the FPP image and start installing on your SD card.
If you should need to select the correct output mode for your display by pressing one of the following number keys on your keyboard;
1. HDMI mode this is the default display mode.
2. HDMI safe mode select this mode if you are using the HDMI connector and cannot see anything on screen when the Pi has booted.
3. Composite PAL mode select either this mode or composite NTSC mode if you are using the composite RCA video connector
4. Composite NTSC mode
1 Note: The builtin Windows formatting tool will only format the first partition that Windows can read not the entire disk. For this reason we advise using the official SD Card Association Formatting Tool.
