Author Topic: P10  (Read 11463 times)
Offline Aesl1982
  • Probation
Re: P10
« Reply #15 on: January 12, 2016, 04:43:11 PM »
ok that's making more sense now. So really for ease of simplicity I could off my network switch have one going to the f16v2 running all the pixels. Then have rons controller off another port running the p10s.
Yes, if you don't want to use FPP.  You can drive Ron's controller from anything that can send E1.31, including FPP, so if you later decide to switch to using FPP as your show player, you'll still be able to use the same P10 controller.
awesome that helps a lot. What a great group here ove learned a lot  the past two weeks from everyone here.  Where do I find this rons controller
Offline Phrog30
  • Kudos: 8
Re: P10
« Reply #16 on: January 12, 2016, 05:34:17 PM »
I think here.
http://ronsholidaylights.com
Offline lwillisjr
Re: P10
« Reply #17 on: January 17, 2016, 06:47:31 PM »
This information is very helpful and I have been researching using P10's as well. I am understanding there are a couple of key functions that need to be performed.
The first is to have a device that picks up the DMX information over an E1.31 network. And there are various controller boards to do this. where many controller boards send this as serial information down a defined port....  the P10 panels require a different type interface. And the boards that do this seem to be sort of a serial to parallel type of interface. Ron's controller board has an optional 'matrix interface' that I assume performs this function. But for the BBB this is where the Octoscroller comes into play.
So if my understanding is correct so far..... I have the following questions.
1. Can you use a Raspberry PI in place of the BBB, does the PI also interface to the Octoscroller? I am not familiar with either, just trying to understand all the options.
2. What is the hardware interface to the Octoscroller, I haven't seen this anywhere. I am starting to assume it is a ribbon cable connection to the GPIO pins on the BBB/PI ??
  • Kudos: 126
Re: P10
« Reply #18 on: January 17, 2016, 08:48:59 PM »
1. The Octoscroller is BBB specific.
2. The BBB has two long interface sockets for interfacing various capes. The Octoscroller is a cape.
Offline gadgetsmith
  • Kudos: 14
Re: P10
« Reply #19 on: January 18, 2016, 06:01:40 AM »
What JonB said.
At this time, there is an ability for the Pi to control P10 panels as well, but not nearly as many as what the BBB is capable of doing. There are updates for the Pi libraries which Chris will be looking at incorporating into FPP 2.0, so my guess is that we might see a new Pi cape for matrix panels this year, but only time will tell. For now, the best solution would be a BBB with Octoscroller.
Offline lwillisjr
Re: P10
« Reply #20 on: January 18, 2016, 06:41:17 AM »
Great, that answered my question. Thanks.
Offline Aesl1982
  • Probation
Re: P10
« Reply #21 on: January 19, 2016, 10:25:58 AM »
My main thing I'm not getting is. Using the Bbb with octo. How does all this work in conjunction with the rest of your show and stay in sync if Ur using two command stations "bbb for panels, and computer or Pi for falcoln v2s"
Offline Livermore-Dad
Re: P10
« Reply #22 on: January 19, 2016, 10:37:37 AM »
Maybe what you are missing is the fact that you treat the BBB like a controller, set it in bridge mode and fire off commands to it from the PI?
Tory
I know some stuff. For example i know I don't know anything.
Offline Aesl1982
  • Probation
Re: P10
« Reply #23 on: January 19, 2016, 10:59:16 AM »
Tory
ok so it just connects with Ethernet to the network switch coming off the pi. Same way the falcolns are connected then. And if I wanted more than 64 panels I could use two bbb'a in bridge mode off the switch
Offline Aesl1982
  • Probation
Re: P10
« Reply #24 on: January 19, 2016, 11:15:50 AM »
I was wanting to do something like a 7' tall by 15' wide p10 matrix. To cover my garage door. Maybe I'd be better off using regular 2822 and couple pixel nets
Offline gadgetsmith
  • Kudos: 14
Re: P10
« Reply #25 on: January 19, 2016, 11:39:46 AM »
Yowsa! That's about 14x14 p10 matrix, or 196 p10 panels. If you dropped to 14x13, you'd have 182 p10 panels, which you'd control with 3 BBB/Octo setups. Ambitious; Can't wait to see it! :)
Offline Aesl1982
  • Probation
Re: P10
« Reply #26 on: January 19, 2016, 11:48:30 AM »
tah haven't decided yet looking at cost I could use regular 2811 nodes at 1" for 6k oixels or 2" for 3k oixels and be cheaper and less hassle than the p10s.
Offline Aesl1982
  • Probation
Re: P10
« Reply #27 on: January 19, 2016, 11:52:18 AM »
tah haven't decided yet looking at cost I could use regular 2811 nodes at 1" for 15,000 oixels or 2" for 3700 oixels and be cheaper and less hassle than the p10s. Doesn't seem right the numbers. Because going from 2" to 1" spacing should just double the count but it doesn't work that way
Offline gadgetsmith
  • Kudos: 14
Re: P10
« Reply #28 on: January 19, 2016, 11:55:16 AM »
If you change the spacing in one direction it's 2x, but in two directions it's 4x.
  • Kudos: 126
Re: P10
« Reply #29 on: January 19, 2016, 11:55:37 AM »
I have been using a nearly 8ft by 4ft pixel matrix on my garage door for 3 years. 2 inch spacing. WS2811 pixels. 1200 pixels (40 x 30)
It runs from a single Falcon F16v1 controller and a single 12vdc power supply.
It just doesn't get much simpler than that, though perhaps it could be larger!!  I use 10 strings, folding 3 times (in xLights, not the controller)
https://vimeo.com/149528977
