Author Topic: Weird issue with Falcon SSC firmware (128 node backwards)  (Read 1456 times)
Offline Frankr
    • Rocklin Lights
« on: November 17, 2013, 11:20:44 AM »
Hello all,
I just reprogrammed 2 different SSCs, a moded v1 and a modded v2,  both were programmed to be 128 nodes backwards addressing. For some reason the nodes that should be 1-8 are locking on one color and not changing like the rest of the string. I tried 2 different strings with the same behavior.
Any thoughts?
Frank
Offline Frankr
    • Rocklin Lights
Re: Weird issue with Falcon SSC firmware (128 node backwards)
« Reply #1 on: November 17, 2013, 11:28:45 AM »
Adding data as I go. Just did a unmodded v2 on a third string and got the exact same results.
Updating...
Changed to forward on that last ssc and the string behaves properly.
Frank
Offline Frankr
    • Rocklin Lights
« Reply #2 on: November 17, 2013, 02:58:54 PM »
For the record this was a PEBKAC problem (problem exists between Keyboard and Chair...).  I was not paying attention to the fact that the falcon grouping software defaults to 10 groups.  When I switched back to only one group everything works as expected.
Thanks again to David for taking time out of his day to straighten me out <FacePalm>
Frank
  • Kudos: 68
« Reply #3 on: November 18, 2013, 07:32:01 AM »
A lot of us have gotten hit with the default of 10 on the grouping.  I wish David would change the default to 1 and make a settings file where we could set defaults that we want to use.
Offline rdebolt
    • Christmas in Boise
« Reply #4 on: November 18, 2013, 08:45:58 AM »
+1
  • Kudos: 80
« Reply #5 on: November 18, 2013, 12:45:49 PM »
+1
You guys are right. I have had two people in last two days that had a problem because of default being 10. I will change it early next year.
