Author Topic: trouble with 5x6 p10 panels  (Read 882 times)
Offline bassnbuck
« on: March 02, 2016, 08:43:06 AM »
i got my matrix working last night but this morning when i was doing more testing i noticed my bottom 5 rows of pixels weren't synced up with the rest of the matrix.  any thoughts?
  • Kudos: 205
Re: trouble with 5x6 p10 panels
« Reply #1 on: March 02, 2016, 07:59:34 PM »
Can you double check your last few universes in FPP and xLights to make sure they match up exactly?
Offline tripplett
  • Kudos: 4
« Reply #2 on: March 02, 2016, 08:31:07 PM »
When I set mine up it helped to go into the test page of XLights.  I turned on just the first and last LEDs of my p10 panels and discovered that my model channel assignments were off.  Make sure you click the output to lights button too if you do this.
Offline bassnbuck
« Reply #3 on: March 03, 2016, 05:42:06 AM »
thanks for the replies.  i think i figured it out when i switched the first ribbon cable with the one that was having trouble then the top row started to have that issue, So it appears that my ribbon cable is bad.
  • Kudos: 118
« Reply #4 on: March 03, 2016, 06:03:48 AM »
before tossing out that cable, try "squeezing" it or tapping it with a mallet to make better contact. Probably a single wire not getting pierced completely.
Offline bassnbuck
« Reply #5 on: March 03, 2016, 08:22:29 AM »
good idea i will try that.  thanks
