Author Topic: F16V1, F8 and Falcon Pixelnet Hub Interest Thread for 2016  (Read 5681 times)
  • Kudos: 80
F16V1, F8 and Falcon Pixelnet Hub Interest Thread for 2016.
Trying to gauge interest for these Pixelnet based products. They will be all assembled and pricing is based off quantities required. Most likely will be handled from PixelController.com store front to keep the transactions straight. I estimate the prcing to be similar to last years group buy if quantities are in same ball park.
Offline deplanche
Re: F16V1, F8 and Falcon Pixelnet Hub Interest Thread for 2016
« Reply #1 on: May 07, 2016, 05:38:35 PM »
Is there a location that describes what these controllers do and the differences between them?  I tried a search and not coming up with many results.
  • Kudos: 127
« Reply #2 on: May 07, 2016, 07:30:43 PM »
They each have their own Forum entry. Also should be covered in the Wiki.
Offline tomwb301
  • Kudos: 4
« Reply #3 on: May 07, 2016, 07:35:07 PM »
I still run F16v1 boards. They work great. I'd be interested in a couple of boards as back up boards.
Thanks David.
Tom
Crosby, Texas
Offline deplanche
« Reply #4 on: May 07, 2016, 07:40:36 PM »
I couldn't find anything on the F-8 or Hub in the wiki.  Could you post a link?  The info in the forum topics explains some, but not too much, especially on the F-8.
Offline chadowamsley
« Reply #5 on: May 07, 2016, 10:18:59 PM »
I would probably be in for :
Falcon F16 - 3
Falcon Hub - 1
  • Kudos: 68
« Reply #6 on: May 08, 2016, 02:42:57 PM »
The F16v1 and the F8 are basically pixelnet boards, ie. you feed them pixelnet signals not e1.31 signals.  They work great and  I run them along with DLA Lynx Active and Passive hubs.  An f16v2 receives e1/31 data and can output to lights, to a pixelnet controller, a LOR controller, a renard controller, etc.  So if you had an F16v2 you could use that instead of a DLA Etherdongle to generate the pixelnet.  Just my simple explanation.
Offline twooly
« Reply #7 on: May 08, 2016, 02:56:07 PM »
I would be I interested in a f8 and possibly a f16.
Offline bassmants
« Reply #8 on: May 08, 2016, 09:18:58 PM »
Yes, definitely 2 f16 v1s and maybe and f8.
Offline Frankr
    • Rocklin Lights
« Reply #9 on: May 09, 2016, 01:21:01 PM »
I would be in for
2--F16v1
4--Falcon Hub
Frank
Offline Unibits
« Reply #10 on: May 09, 2016, 03:47:02 PM »
hubs - 3 in total
Offline RichM
« Reply #11 on: May 09, 2016, 06:50:54 PM »
I would be interested in the following as backup units or possible future expansion:
1- F16v1
1- F8
Thanks.
Offline Griz
« Reply #12 on: May 09, 2016, 10:10:44 PM »
Question - if I have a Fv2R it can run a hub or Fv1, correct? I know that I'll need more controllers for the massive amounts of pixels I need to buy, so couldn't I use my Fv2R as a master controller to drive a Fv1 or hub opposed to buying more Fv2Rs?
I know the Fv2R is awesome, but how many is too many? I assume you can never have to many but still.
  • Kudos: 80
« Reply #13 on: May 09, 2016, 11:35:35 PM »
Many people drive F16V1 and hubs from the F16V2.
Offline sirloinofbeef001
  • believe in miracles
« Reply #14 on: May 10, 2016, 07:42:34 AM »
2 f16v1
Its a wonderful life.
