Author Topic: F8-Distro  (Read 11689 times)
  • Kudos: 75
F8-Distro
« on: June 01, 2016, 06:24:06 PM »
I had an extra 30 minutes so I whipped up this board. Very similar to Andy's 6 port version as well as other Falcon expansion/controller power sections. It has eight ports with pluggable connectors. I plan to hold stock at PixelController.com.
  • Kudos: 109
Re: F8-Distro
« Reply #1 on: June 01, 2016, 06:44:37 PM »
I do like the pluggable connectors. I have had to scrounge around for a screwdriver (sometimes hard to find a small one) just to disconnect a pair of wires.
And 8 matches up with the "groups of 8" that almost all pixel controllers seem to use. Good for power injection folks. (like Mark V)
Offline Dinkyr
Re: F8-Distro
« Reply #2 on: June 01, 2016, 06:46:48 PM »
Hi David,
How soon will this be available? Any target price?
  • Kudos: 75
Re: F8-Distro
« Reply #3 on: June 01, 2016, 06:50:01 PM »
Within a few weeks. I am hoping to keep price low. I am getting quotes today should expect pricing in a day or two. We can still reduce the height by .1mm
« Last Edit: June 02, 2016, 07:50:32 PM by David Pitts »
Offline Dinkyr
Re: F8-Distro
« Reply #4 on: June 01, 2016, 07:06:44 PM »
Hmmm. Might have to ask you to hold off on delivery of my orders again. This so I can decide whether to add these to my order.  :)
  • Kudos: 75
Re: F8-Distro
« Reply #5 on: June 01, 2016, 07:10:31 PM »
OK. I should get them at about same time or one week after differential boards.
Offline Dinkyr
Re: F8-Distro
« Reply #6 on: June 01, 2016, 07:19:37 PM »
Great. I'll be waiting.
Offline Skunberg
Re: F8-Distro
« Reply #7 on: June 01, 2016, 07:24:27 PM »
I'd be interested also. I hope the price is right.
Offline needbrew
Re: F8-Distro
« Reply #8 on: June 02, 2016, 04:16:08 AM »
I would be interested as well.
Offline rlemery
Re: F8-Distro
« Reply #9 on: June 02, 2016, 06:29:05 AM »
I'm also interested.
728 lor channels
5492 pixels
Offline mararunr
    • Bentonville Heart Lites
Re: F8-Distro
« Reply #10 on: June 02, 2016, 06:51:07 AM »
Wow, 40 amp!  Nice.  Interested as well.
  • Kudos: 75
Re: F8-Distro
« Reply #11 on: June 02, 2016, 07:31:43 AM »
The main connector is rated at 30-32 amps so not 40 amps. But it is similar to F16V2 where each side of F16V2 has 8 connectors with 5amp fuses but each side is rated at 30 amps max.
Offline Emuney18
  • Kudos: 7
Re: F8-Distro
« Reply #12 on: June 02, 2016, 09:22:21 AM »
I could definitely use 2 as I had originally planned to use 4 of Andy's boards in pairs.  These would be a little cleaner like looking.
  • Kudos: 34
Re: F8-Distro
« Reply #13 on: June 02, 2016, 04:51:14 PM »
I'm in, but curious about something...
Something like this I would want to be as small as possible.  It appears from the picture that there is space between the pluggables that maybe could be reduced.  Is the size of the copper traces dictating the apparent wide spacing or could this be compacted a bit more?
  • Kudos: 75
Re: F8-Distro
« Reply #14 on: June 02, 2016, 04:54:22 PM »
Something like this I would want to be as small as possible.  It appears from the picture that there is space between the pluggables that could be reduced.  Is the size of the copper traces dictating the current spacing or could this be compacted a bit more?
It is 2.9" x 1.8. It is pretty small.
