Author Topic: F8-Distro  (Read 11690 times)
  • Kudos: 75
Re: F8-Distro
« Reply #15 on: June 02, 2016, 05:11:50 PM »
This version is 2.6 x 1.7 (66mm x 43mm). :) But the holes are not in the corners.
  • Kudos: 34
Re: F8-Distro
« Reply #16 on: June 02, 2016, 06:47:52 PM »
Awesome!  That's exactly what I was visualizing in my mind.  ;D
Offline Aesl1982
  • Probation
Re: F8-Distro
« Reply #17 on: June 02, 2016, 07:45:10 PM »
The first. Version with holes in corners seems would mount better and .3x.1 isn't much of a difference
  • Kudos: 75
Re: F8-Distro
« Reply #18 on: June 02, 2016, 07:48:05 PM »
I agree. The holes distances were also on 1/4" multiple.
  • Kudos: 34
Re: F8-Distro
« Reply #19 on: June 02, 2016, 09:31:51 PM »
As I said originally, I was just curious about the spacing. It looked bigger than necessary, but I'm fine with it either way.  It's not a big deal.  I'm just brainstorming out loud like I usually do  ::)
I primarily anticipate using these for p10 panels but I'm still waiting for my panel kits to arrive.  Also waiting to see what Boscoyo comes up with for enclosure and mounting things inside it.
  • Kudos: 75
Re: F8-Distro
« Reply #20 on: June 03, 2016, 06:08:15 AM »
Got pricing back. The price will be $15.00 a piece and i will have them in stock in 3 weeks. I will have them in the store later today to pre-order.
Offline markrvp
  • Kudos: 7
Re: F8-Distro
« Reply #21 on: June 03, 2016, 07:21:34 AM »
$15 is certainly a just and fair price.  To create an eight output power distribution block for my mega tree boxes I had to use a
1.) Fuse block: http://www.amazon.com/HELLA-H84960111-8-Way-Lateral-Single/dp/B000VU9D20/ref=sr_1_3?ie=UTF8&qid=1464959511&sr=8-3&keywords=fuse+block
2.) Screw terminal: http://www.amazon.com/TOOGOO-Position-Terminal-Covered-Barrier/dp/B005I03WOI?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
3.) Barrier strip: http://www.amazon.com/URBEST-Postions-Insulated-Terminal-Barrier/dp/B00NVG78ZK?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
4.) Fuses
5.) Quick connects (for the spade plugs on the fuse block)
Total to build that out was right at $15 and took way longer than just screwing wires into a pre-built distribution block.
  • Kudos: 75
Re: F8-Distro
« Reply #22 on: June 03, 2016, 08:36:13 AM »
OK. it is the store. I have them on order and will have them by the time I get back from CA.
http://pixelcontroller.com/store/index.php?id_product=46&controller=product
  • Kudos: 109
Re: F8-Distro
« Reply #23 on: June 03, 2016, 10:59:10 AM »
Sure, but what COLOR will they be?
  • Kudos: 75
Re: F8-Distro
« Reply #24 on: June 03, 2016, 11:19:53 AM »
Red
Offline Setarcos
  • Kudos: 6
Re: F8-Distro
« Reply #25 on: June 03, 2016, 12:02:09 PM »
Jeesh, I go on vacation for a few days and David has been at it again ;) Glad I held off on building/buying a power distribution board. This one hits all my checkboxes.
Offline Dinkyr
Re: F8-Distro
« Reply #26 on: June 03, 2016, 06:59:16 PM »
Hi David,
I have a couple of questions. I know that there is a safety factor built into these boards as to carrying capacity.  What is the maximum load it can carry per circuit and what could be the maximum main fuse limit? The reason I ask is because some people use converted server power supplies and some of those can go up to 62 amps and instead of using 2 regular power supplies, we can use just one for say a 16 strand (8 strings) x 50 pixel megatree injected every 100. What are your thoughts on this one? Thanks.
  • Kudos: 75
Re: F8-Distro
« Reply #27 on: June 03, 2016, 07:21:07 PM »
30 amp max. So 30 amp fuse
Offline FrankP
Re: F8-Distro
« Reply #28 on: July 11, 2016, 05:13:12 PM »
Hi Dave,
Any updates on when the orders will be shipping?
Thanks!
Frank
  • Kudos: 75
Re: F8-Distro
« Reply #29 on: July 11, 2016, 05:26:10 PM »
The boards will be here Wednesday. I will be at Expo so when I get back on Sunday I will ship them. I expect to have all boards shipped by Tuesday the 19th.
