Author Topic: **Closed** Power Distro RevB group buy **Closed**  (Read 30492 times)
Offline whitebuck
Re: **Closed** Power Distro RevB group buy **Closed**
« Reply #165 on: November 10, 2016, 07:37:20 PM »
Andy,
You don't happen to have a 1:1 drawing of the hole spacing do you?  I want to make a drill template to make mounting easier to mark and drill?
Thanks,
Mike
Whitebuck
Offline harrison0550
  • Kudos: 8
    • Soddy Daisy Christmas Lights
« Reply #166 on: November 10, 2016, 08:31:59 PM »
Andy,
Thanks,
Mike
Whitebuck
I do. However it comes with a warning. You have to download the PDF and use adobe acrobat to open the PDF and select "Actual size" when you print it. If you use any other PDF viewer or internet explorer, or try to print from one drives preview etc. it will not print the correct size. I would recommend you check it with a distro board over it after you print one to make sure you printed it correctly.
Here is the link....
https://1drv.ms/b/s!Ap1ZCXyLMTBYg4941SfY1M9ashppEA
Offline jaysdisaster
« Reply #167 on: November 10, 2016, 10:38:03 PM »
Andy,
Thanks,
Mike
Whitebuck
I used a fine tip sharpie
Offline whitebuck
« Reply #168 on: November 14, 2016, 07:02:45 AM »
Andy,
Thanks,
Mike
Whitebuck
Thanks,  I will try the printout.
I tried a sharpie and was just looking for a better way.
Offline battle79
« Reply #169 on: November 18, 2016, 10:34:42 PM »
Hi Andy,
What is the max rating for the input and outputs of the units? IE Can I use a 10amp fuse in one output if I leave another one unused?
Spend 30min looking for the answer, and I believe I did read it somewhere previously, but cannot find now.
Regards,
Rowan
  • Kudos: 8
« Reply #170 on: November 19, 2016, 06:52:37 PM »
The input plug is rated at 30 amps. The output plugs are rated at 15 amps max each. So technically you could run 2 of the output plugs as 15 amps and leave the other outputs empty but I probably wouldn't use a power distro board for that though. I would use an inline fuse or something.
Offline battle79
« Reply #171 on: November 20, 2016, 12:55:58 AM »
Thanks for quick reply Andy,
I actually need 2x 10amp, 2x 5amp, and 1x controller board (just going to leave as 5amp) so this will be a good fit,  and probably still cheaper that inline fuses.
Regards,
Rowan
Offline whitebuck
« Reply #172 on: November 28, 2016, 09:03:44 AM »
Here is my matrix in test mode with Andy's Power Injection Board.https://vimeo.com/193386470
Thanks,
Mike
  • Kudos: 8
« Reply #173 on: November 28, 2016, 09:06:12 AM »
Looks great! I ended up running 15 of those power distro boards in my display this year. Love opening up the controller boxes and seeing the green glow of the leds!
Offline whitebuck
« Reply #174 on: November 28, 2016, 09:20:58 AM »
Sure helps tell that power is going to where you want it to.  I am using 3 at the moment and you can see the box below the matrix.  Saves on wire length too.
Offline rstehle
« Reply #175 on: December 11, 2016, 02:03:39 PM »
Any chance of another run of these in early 2017?
Offline myoung84
« Reply #176 on: December 11, 2016, 08:49:24 PM »
I'd like a few of these as well for next year. Going to be buying a v3 when it comes out...
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline burtonmadness
« Reply #177 on: July 06, 2017, 03:13:59 PM »
Is there going to be a new GB for this in 2017?
  • Kudos: 68
« Reply #178 on: July 06, 2017, 07:16:46 PM »
You might order the Falcon Distro Board from pixelcontroller.com.  They are in stock.  Look under popular tab.
Offline pmiller
« Reply #179 on: July 23, 2017, 10:21:19 PM »
I realize the group buy is closed. Does anyone have 5-6 spares they would like to sell? I live in the USA and I can't find anything here that has 6 outputs with LED indicators.
