Author Topic: what size are the mounting screws on the power supplies  (Read 1853 times)
Offline FireMedic4Christ
« on: July 21, 2016, 11:34:15 PM »
Mounting my controllers and power supplies, but couldn't find the size of screw needed to mount the power supply to the mounting plate. I thought I bookmarked a link to some plastic ones but can't find it.
Thanks in advance,
Brian
Brian
Offline AAH
  • Kudos: 19
  • Blinky blinky blinky
    • I love blinky lights
Re: what size are the mounting screws on the power supplies
« Reply #1 on: July 22, 2016, 01:17:50 AM »
Depending on which hole and which power supply they will either be M3 or M4. The 3mm are the most common. Make sure that they aren't too long if you are screwing into 1 of the mounting holes that has the pcb behind it as it's possible to break the insulator that's behind the hole and short things out.
