Author Topic: 6th row of a 5x6 P10 lagging  (Read 1151 times)
Offline brianweb
« on: September 26, 2016, 07:49:20 PM »
I have a 6wX5h p10 running from a BBB/Octoscoller.  The bottom row of panels (Output 6) appear to have more artifacts and certain rows seems to lag behind a bit.  What are the troubleshooting options, different data cable?  Anything else?
Thanks,
Brian
Offline rlemery
Re: 6th row of a 5x6 P10 lagging
« Reply #1 on: September 26, 2016, 09:08:31 PM »
What model are you running in. Are you testing in bridge mode or master with  a fseq file loaded on the bbb?
728 lor channels
5492 pixels
Offline rlemery
« Reply #2 on: September 26, 2016, 09:09:17 PM »
Meant mode.  Auto correct.  Lol
  • Kudos: 124
« Reply #3 on: September 26, 2016, 09:14:57 PM »
I'd suspect a flaky cable from the BBB to the first panel. Try a new one or swap them around.
Offline brianweb
« Reply #4 on: September 26, 2016, 09:27:39 PM »
It is the Industrial version of the Beagle Bone Black.  I am running it on Bridge mode from Xlights just testing things out.  Does running straight from the BBB result in a smoother playback?  I will also try swapping out the data cable tomorrow.
Offline rlemery
« Reply #5 on: September 26, 2016, 09:29:34 PM »
Try loading the file onto the BBB. Some have reported the same issue in bridge mode. To much data transfer.
Offline rlemery
« Reply #6 on: September 26, 2016, 09:33:53 PM »
You figure in bridge mode your pushing 46+k of data over e1.32
Offline rlemery
« Reply #7 on: September 26, 2016, 09:34:23 PM »
You figure in bridge mode your pushing 46+k of data over e1.31
Offline AAH
  • Kudos: 19
  • Blinky blinky blinky
    • I love blinky lights
« Reply #8 on: September 27, 2016, 03:41:18 AM »
6x5 is 30 panels and 90 universes of data being sent to the BBB. If you look on the status page of the FPP you will probably see that latter universes are getting less updates than the first ones. This bottleneck can be your pc, the router or the front end of the BBB. For testing using the BBB in bridge mode is fine but for reliable playback and less network traffic you're better off using it as either a master or slave on a FPP controlled network.
  • Kudos: 68
« Reply #9 on: September 27, 2016, 07:57:30 AM »
Swapping cables sure helped me out.  You can just swap the existing one by moving them to different positions and see if the problem follows the cable.
