Author Topic: Does F16 turn lights off after some period of time?  (Read 761 times)
Offline pk
« on: December 09, 2013, 08:33:31 AM »
I have some F16 display elements set to all white for an extended period of time.  About every 5 seconds the strings blink off aand then immediately back on.  Is this normal?
  • Kudos: 76
Re: Does F16 turn lights off after some period of time?
« Reply #1 on: December 09, 2013, 08:36:18 AM »
If the Pixelnet stream is interrupted it will turn lights off after a couple seconds.
Offline pk
« Reply #2 on: December 09, 2013, 09:26:01 AM »
ok thanks for the info.  I have noticed some other errors on that controller.  The cat5 cable to it is approaching 100' in length.  I will investigate further when the weather gets warmer.  MMS and I are probably the only ones that notice the glitch!!
Offline mms
« Reply #3 on: December 09, 2013, 10:19:10 AM »
...and you thought it was part of the sequencing!
If you use the test mode in Vixen, they'll shut off after about a second.  I test in xLights/NC and they don't go out.  Even when you're testing just one channel.
Offline rdebolt
    • Christmas in Boise
« Reply #4 on: December 09, 2013, 12:20:58 PM »
I am seeing this same issue, but on all controllers not just the 16. I am not seeing any problems with a sequenced song, but if I just have them commanded on I will get a blink every once in a while. Maybe a second off then back on. It is enough that the first time it did it I though I was having problems. The funny thing is it is not all controllers at once. It may be one then another. But it is always a whole controller, not just a few lights.
Running FPP>FPD>Controllers.
