Author Topic: Hub confusion  (Read 1624 times)
Offline Bob in WV
Hub confusion
« on: October 26, 2016, 09:15:14 AM »
 Having a mental block (old age) with regards to addressing my Hub.
I have a prop with a starting address of 9937.  I set my Hub addresses to 2 & 2 for A and 3 & 3 for B.
When I use xlights to test the lights they start at 5842.  I seem to be off one universe, but I don't understand why.
Bob in WV
Re: Hub confusion
« Reply #1 on: October 26, 2016, 09:47:51 AM »
When you programmed the *SC, which start channel did you specify in the UI?
Offline Bob in WV
Re: Hub confusion
« Reply #2 on: October 26, 2016, 09:52:59 AM »
Chris - 9937
Re: Hub confusion
« Reply #3 on: October 26, 2016, 10:14:23 AM »
What is feeding the pixelnet signal to the hub, is it a F16v2 or EtherDongle or ??
And just to make sure, is the *SC plugged into one of the groups of 4 ports that is set to universe 'B'?
Offline Bob in WV
Re: Hub confusion
« Reply #4 on: October 26, 2016, 02:15:28 PM »
I am feeding the Hub from a FPD primary port.
There is no output on any of the ports when sent to 9177.
I tried on a second Hub and have the same problem.
I connected another model with an address in the second universe and it works fine, but it works on all outputs on the hub!
Bob
Re: Hub confusion
« Reply #5 on: October 26, 2016, 04:01:40 PM »
Did you set the A/B jumpers on the individual groups of 4 outputs so that some are on Universe B?
Offline Bob in WV
Re: Hub confusion
« Reply #6 on: October 26, 2016, 08:57:56 PM »
A OXOO OXOO
B OOXO OOXO
Bob
Re: Hub confusion
« Reply #7 on: October 26, 2016, 09:52:35 PM »
Look beside the output RJ45 jacks for the SSC's, there is a 3-pin jumper for each set of 4 jacks.  The jumper is labeled "A B" and let's you specify whether those 4 jacks are on the "A" universe (2 in your case) or the "B" universe (3 in your case).  There are 4 of these 3-pin jumpers scattered around the board.  Each 3 pin controls 4 output jacks.
Offline Bob in WV
Re: Hub confusion
« Reply #8 on: October 27, 2016, 02:59:27 PM »
Chris I must have slept through the jumper class.  I missed those jumpers completely.
Thanks for you patience-
Bob
Re: Hub confusion
« Reply #9 on: October 27, 2016, 03:23:55 PM »
Glad you got it working.  I don't have one of these boards so was going from memory and re-checking the assembly manual PDF.
