Author Topic: Its coming, PiCap  (Read 7548 times)
Offline kmc123
Re: Its coming, PiCap
« Reply #30 on: November 14, 2016, 05:51:29 PM »
The 6 pins by the 2 amp fuse are as follows:
The first two unnumbered pins are jumpered if you want to power the Pi from this board.
The next 4 are numbered 1,2,3 and 4 and are used as follows:
5v = Pin 2&3 Jumpered.
7-24v Pins 1&2 and 3&4 Jumpered.
Offline Cjlocey
« Reply #31 on: November 14, 2016, 06:02:27 PM »
To make sure I do not let the magic smoke out again :o  .....leave the jumper closest to the 40 pin GPIO in place and place a second jumper on the middle of the 4 remaining pins to power the Pi from the cap with a 5v power supply?
Running display on pi's with picaps.....no controllers
Some said it could not be done!  4245 pixels and growing!
xLights & FPP - marriage made in pixel heaven
  • Kudos: 76
« Reply #32 on: November 14, 2016, 06:03:48 PM »
Thanks. I was on the road. This post is accurate.
Offline gc2016
« Reply #33 on: November 14, 2016, 10:07:57 PM »
What's the jumper by R3?
And if I understand the power jumpers correctly
if I have the 2 un-numbered pins jumpered, and 1-2 jumpered and 3-4 jumpered, I can put in 7-24 volts on the cap and 5V will power the Pi?
Offline critic2
« Reply #34 on: November 15, 2016, 04:57:41 AM »
Yes
Chuck P
Still Learning...💡
Offline gc2016
« Reply #35 on: November 15, 2016, 09:48:39 AM »
Fantastic. I'm really looking forward to putting this board to work in our Tiki Bar.
Offline JerryPlak
« Reply #36 on: November 15, 2016, 03:12:41 PM »
Look like tonight's project  ;D
Jerry Plak
Offline jwylie
« Reply #37 on: November 17, 2016, 12:37:33 PM »
Because I'm paranoid and want to make sure I have this correct, do I have the jumpers on correctly to power the pi from the hat and use 5V lights?
Offline critic2
« Reply #38 on: November 17, 2016, 12:43:02 PM »
That looks correct.
Offline kmc123
« Reply #39 on: November 17, 2016, 06:47:55 PM »
Yes - That setup is right for 5v to both.
Offline code
« Reply #40 on: November 19, 2016, 12:58:45 AM »
Have these taken over the pi hat, and if so Will these be back in stock?
  • Kudos: 76
« Reply #41 on: November 19, 2016, 01:05:08 AM »
These will be back in stock on December 14th. I am adding them to the store now.
Offline code
« Reply #42 on: November 21, 2016, 09:35:31 AM »
Thank u
Offline michaelc
« Reply #43 on: November 21, 2016, 09:59:20 PM »
Which pi versions work with these?
  • Kudos: 209
« Reply #44 on: November 23, 2016, 10:37:44 AM »
It works with all the 40-pin versions, but newer quad-core versions will be able to drive more Pixels.
