Author Topic: Got wifi working now can't log in through etho  (Read 623 times)
Offline Aesl1982
  • Probation
« on: November 09, 2016, 05:33:06 PM »
So I got the wifi working on the bbb. However now I can't log in the bbb through etho. It's setup the same as my pi and I have no issues logging into the pi. Here are the pics of the pi setup and the bbb setup
Offline Aesl1982
  • Probation
Re: Got wifi working now can't log in through etho
« Reply #1 on: November 09, 2016, 05:34:44 PM »
Also the 192.168.0.55 doesn't show up in the angryip scanner either however the pi at 192.168.0.54 does
  • Kudos: 214
« Reply #2 on: November 09, 2016, 09:14:15 PM »
Are both systems on the same two networks?
When you say"login", do you mean access the web UI?
What is the IP of the system you are trying to connect from, is it on the wired or wireless network?
Offline Aesl1982
  • Probation
« Reply #3 on: November 10, 2016, 11:12:54 AM »
Didn't see you reply seems it was needing a reboot after activating the wifi on the bbb. After I shut it down and turned it back on I was able to access it through both eth0 and wlan
