Author Topic: Expected behavior not being seen.  (Read 902 times)
Offline MrChristmas2000
  • Kudos: 4
« on: December 16, 2013, 01:01:50 PM »
I have programmed all of my arch SSCs using these settings.
Direction = Forward
Group Mode = Custom Grouping
I defined 8 groups of 13-14 Nodes/group
Checked the 'First RGB  Channel Control Mode'
An example is Arch 1 starting address 12337
In LSP I grouped all the control channels, which in this case would be for Arch 1 12337.
I grouped all the Arch 1 channels into a layer with a beginning channel of 112340
To put the SSC in the pixel mode or non grouped mode it was my understanding that the control channel should be set to a value of 0 (zero).
To switch the SSC to the grouped mode it was my further understanding that the control channel should   be set to a color of White full intensity i.e. a value of 255 in each of the RGB channels.
The results is that the SSC seems to be stuck in the grouped mode all the time.
What am I doing wrong?
Thanks,
  • Kudos: 4
Re: Expected behavior not being seen.
« Reply #1 on: December 16, 2013, 06:10:30 PM »
With Davids help got it figured out.
Using the first channel control mode is awesome.
