Author Topic: MemoryError converting to fseq  (Read 2354 times)
Offline vincerules
« on: December 17, 2013, 08:24:18 AM »
My sequence is about 5 minutes and 34 seconds long and I keep getting this error when trying to load it into FPP.
\christmas-mix01b-01c
Traceback (most recent call last):
  File "C:\Python27\lib\multiprocessing\queues.py", line 262, in _feed
    send(obj)
MemoryError
« Last Edit: December 17, 2013, 04:14:00 PM by vincerules »
Offline Frankr
  • Moderator
    • Rocklin Lights
Re: MemoryError running FPP
« Reply #1 on: December 17, 2013, 09:46:42 AM »
This typically is caused by having controllers that are too large. Though in this case it may be purely due to the length of the song.
David Pitts had a similar issue with his mega tree being all on one controller and we fixed that by just installing the 64bit versions of both python and wxpython.
Frank
  • Kudos: 127
« Reply #2 on: December 17, 2013, 09:51:19 AM »
There is a bigger controller?  I want one! Make that two!
Offline vincerules
« Reply #3 on: December 17, 2013, 10:39:40 AM »
Thanks for the quick response!
I'm at work now, but I'll try installing the 64bit versions later on.
Offline vincerules
Re: MemoryError converting to fseq
« Reply #4 on: December 17, 2013, 07:18:10 PM »
That worked, thanks!!!!!!!!!!
