Author Topic: SOLVED How to configure multiple Pi Caps on one sequence  (Read 1018 times)
Offline Cjlocey
« on: December 03, 2016, 09:53:42 AM »
I am trying to use two picaps for one display.  One to drive my gutter lines and flakes, and the other to drive a pixel matrix with 858 pixels.  I have the pi for the gutters & flakes as the master and the one for the matrix as a remote.  The simple setup in xlights has bars on the house and text on the matrix but the matrix is covered with the bars also.
I am thinking it would be easier to set up the matrix on its own but once I get things set up properly I would like to have hte matrix as part of the overall sequence and I do not see how to do this.
« Last Edit: December 06, 2016, 11:38:26 AM by Cjlocey »
Running display on pi's with picaps.....no controllers
Some said it could not be done!  4245 pixels and growing!
xLights & FPP - marriage made in pixel heaven
  • Kudos: 68
Re: How to configure multiple Pi Caps on one sequence
« Reply #1 on: December 03, 2016, 10:01:32 AM »
Sounds like channel overlap to me.  Run the tools, sequence checker.
Offline Cjlocey
« Reply #2 on: December 03, 2016, 12:40:07 PM »
I am upgrading to the latest "production" version of xlights and I will check that.  Thanks for the reply.
Offline Cjlocey
« Reply #3 on: December 03, 2016, 12:45:47 PM »
No errors.  Only a warning for going .050 over the length, which I fixed. I will see if the new version of xlights helped
Offline Cjlocey
« Reply #4 on: December 06, 2016, 11:38:15 AM »
RESOLVED!  Second Pi setup would have the RPI281x output 1 set to the next channel after the last one used on the previous Pi.  Thanks to Gadgetsmith for the help
